RV8-List Digest: 4 Msgs - 08/31/13
speedy11(at)aol.com
PostPosted: Mon Sep 02, 2013 5:40 am    Post subject: RV8-List Digest: 4 Msgs - 08/31/13 Reply with quote
Dennis,
I would stay with the Van's supplied brake lines - at least dimensionally. I believe you are trying to save weight in the wrong place.
There are compatibility problems with using automotive fluids. It will destroy the seals which are designed for use with 5606.
Stan Sutterfield
Reno Race 84
My RV8a project is ready for wheels, and I keep thinking about the brake
system and lines. Seem to me like some weight could be saved by going with
3/16 brake lines, (smaller line and less fluid). Problem with small lines
is the heavy viscosity of A/C hydraulic oil, especially when cold.
Solution would be automotive Dot 3 or Dot 4, but are there compatability
issues with the Matco master cylinders and Cleveland calipers? Maybe new
o-rings could solve the problem? Anyone know the answer?
