audio panel alternative
graybeard
PostPosted: Mon Aug 19, 2013 1:48 pm    Post subject: audio panel alternative Reply with quote
Responses to my comm. radio installation question opened up a new path. As a result (thanks, Robin), I am now looking at a dual Garmin GTR 200 installation on the upper left side of the panel. However, since I will be VFR only with the Dynon Skyview system, I see no reason for an audio panel. Even the simplest ones I have seen have far more capability than I will ever need. What I think I am looking for is a simple way to switch the mic. input and audio output back and forth between radios, possibly through a switch on the stick grip. May be more involved than that. This is outside the envelope of my limited electronics knowledge, so I will take all the help I can get.
Stan Loer
RV-8 QB
