Wing lift and drag pins
spcialeffects
PostPosted: Sat Aug 17, 2013 11:59 am    Post subject: Wing lift and drag pins Reply with quote
Hi all, so im building a classic and am just finishing off my wings. In the combined manual chapter 26 it says that the holes for the wing pins are already drilled and tapped (you XS people dont know what your missing out on!! ) but i need to drill and tap mine myself, so does anyone have the original instructions for measurements to position the pins? Many thanks
pete(at)lawless.info
PostPosted: Sat Aug 17, 2013 1:54 pm    Post subject: Wing lift and drag pins Reply with quote
Do you mean the 2 lift/drag pins in the wing root? If so I can scan and send
the appropriate pages. However, prepare yourself for a shock! Check out
mandatory mod 74 on the Europa website. The rear pin needs to be changed
for a longer one with a big washer and nut on the back inside the wing.
There is a variation of the instructions for mod 74 which allows you to go
in through the rear close out.
Let me know if you need the pages and I will scan and send in the morning.
Pete
nigel_graham(at)m-tecque.
PostPosted: Sat Aug 17, 2013 2:04 pm    Post subject: Wing lift and drag pins Reply with quote
Here you go. The information you need is to be found in Chapter 10 - 67
of the original Fuselage manual - looks like it was overlooked when the
"Combined Build Manual" was compiled. I have scanned both pages for you
and also included the mandatory mod that you will need to incorporate in
your Classic Wing.
Nigel
On 17/08/2013 20:59, spcialeffects wrote:
Hi all, so im building a classic and am just finishing off my wings. In the combined manual chapter 26 it says that the holes for the wing pins are already drilled and tapped (you XS people dont know what your missing out on!! ) but i need to drill and tap mine myself, so does anyone have the original instructions? Many thanks
http://forums.matronics.com/viewtopic.php?p=406925#406925
 Filesize:  631.81 KB
 Viewed:  9324 Time(s)
 Filesize:  908.08 KB
Mod_74_-_Wing_Pin_Strengthening_-_MANDATORY_.pdf
 Filename:  Mod_74_-_Wing_Pin_Strengthening_-_MANDATORY_.pdf
 Filesize:  595.16 KB
 Downloaded:  618 Time(s)
spcialeffects
PostPosted: Sat Aug 17, 2013 8:14 pm    Post subject: Re: Wing lift and drag pins Reply with quote
Thanks Nigel its that first page that I'm after. I couldn't remember who sent me the wing layup papers (using the uni cloth) before (thanks again). I am doing mod 74 but there is no way of incorporating this before having skinned the foam so I have to cut a hole in the skin to fit the mod. Fortunately it hasn't got any filler on it so this makes it a little easier.
PostPosted: Sat Aug 17, 2013 11:21 pm    Post subject: Wing lift and drag pins Reply with quote
Just another memory from the very distant past - we also had to change the
front pin for a longer one. Be worth checking that the front pin you have
is the correct size. Can't find it in the mod list on the Europa site but I
think it was introduced 2000 ish.
PostPosted: Sun Aug 18, 2013 12:04 am    Post subject: Wing lift and drag pins Reply with quote
Actually earlier than than Pete, The long pin mod date was 14th Sept '95
and can be found as part of the Issue 10 Fuselage manual.
Nigel
ptag.dev(at)tiscali.co.uk
PostPosted: Sun Aug 18, 2013 1:17 am    Post subject: Wing lift and drag pins Reply with quote
Hi! All ,
On subject of the lift pins and mods. I would like to offer another fact
that the front lift pins were also changed to upgrade the material they were
made from.
Bob Harrison G-PTAG Kit 337 Classic /XS hybrid now with over 1000 hours on
the airframe.
spcialeffects
PostPosted: Sun Aug 18, 2013 3:36 am    Post subject: Re: Wing lift and drag pins Reply with quote
One other question please. The instruction page above says to drill the flap pin in the middle of the plates but the combined manual gives an off centre position. Why is there a difference of position and which is best to use?
davidjoyce(at)doctors.org
PostPosted: Sun Aug 18, 2013 9:23 am    Post subject: Wing lift and drag pins Reply with quote
Sorry, don't see to have a name for you! I would very
much advise putting the pin in the middle of the plates.
When William Mills plane broke up in. Mid air on a Max
weight VNe dive there were two things that failed and it
was never decided which was the primary factor, (although
I prefer the notion of the tail plane fixation having
failed). However one was that a front lift pin had been
drilled into the front edges of the 3 plates in the wing
root, reaching the edge of one and overlapping another,
which meant that it was taking considerable strains on a
metal to fibreglass joint which is not in the owner's long
term interests! That is not exactly a reason for being
central but a very good reason for not being anywhere near
the edge as I dare say that you cannot know precisely
where the deeper plates are situated.
Regards, David Joyce, G- XSDJ
On Sun, 18 Aug 2013 04:36:20 -0700
use?
http://forums.matronics.com/viewtopic.php?p=406953#406953
Un/Subscription,
Forums!
Admin.
PostPosted: Mon Aug 19, 2013 5:27 am    Post subject: Wing lift and drag pins Reply with quote
Afternoon All
I recommend the following link for the official report into the in flight
break up.
http://www.aaib.gov.uk/cms_resources.cfm?file=/Europa,%20G-HOFC%2005-08.pdf
Pete
MJKTuck(at)cs.com
PostPosted: Mon Aug 19, 2013 4:10 pm    Post subject: Wing lift and drag pins Reply with quote
So the purpose of diving to VNe as part of the annual inspection is to
determine what?
Martin Tuck
Europa N152MT
Wichita, Kansas
On 8/19/2013 8:25 AM, Pete Lawless wrote:
Afternoon All
break up.
Pete
frans(at)privatepilots.nl
PostPosted: Tue Aug 20, 2013 4:22 am    Post subject: Wing lift and drag pins Reply with quote
determine what?
To see whether the aircraft can handle it. The test obviously fulfilled
its purpose.
On the other hand I would not feel comfortable cruising in an aircraft
at 140+ knots without knowing whether it can not even handle 163 knots
without breaking apart.
I have to admit I flew mine one time inadvertently shortly past Vne
(attempting to get down to an assigned altitude before entering the busy
Brussels TMA while being distracted by the radio and navigation at the
same time) but apart from the ASI needle position there was nothing
different than flying at lower speeds.
How was the Vne speed actually established? Why was it 163 and not 160,
or 170? I don't have the impression that the speed where flutter or
other bad things occur has been determined by actual flight- or wind
tunnel tests. I have seen other aircraft with exactly the same Vne
number. Is this value of 163 knots some sort of default value when no
factual data is available?
(No, I'm not voluntary going to explore this area. I'm just wondering,
especially because the cruise speed is so close to the Vne and the
Europa can build up speed very quickly when the pilot is distracted. I
also wonder what likely is to happen when the real, likely still
unknown, Vne is reached).
Frans
PostPosted: Tue Aug 20, 2013 5:09 am    Post subject: Wing lift and drag pins Reply with quote
Frans, As I understand it VNe (which for me is 165 kts) is
90% of Vdf or demonstrated flight diving speed so that I
guess Europa flew the prototypes at 183 kts to give the
rest of us a bit of a margin for error. They probably
thought that with the designed engines it wasn't likely
that folk would want to or be able to go much faster and
design theory suggested that 183kts would be OK, always
assuming of course that the plane was constructed
properly. Regards, David Joyce, G-XSDJ
On Tue, 20 Aug 2013 14:21:26 +0200
>inspection is to
> determine what?
obviously fulfilled
its purpose.
in an aircraft
handle 163 knots
shortly past Vne
entering the busy
navigation at the
was nothing
163 and not 160,
flutter or
flight- or wind
the same Vne
value when no
just wondering,
Vne and the
distracted. I
likely still
Frans
Un/Subscription,
Forums!
Admin.
paul.the.aviator(at)gmail
PostPosted: Tue Aug 20, 2013 8:10 am    Post subject: Wing lift and drag pins Reply with quote
Dave, (or anyone I guess)
Do you happen to know what, into choosing a demonstrated design dive speed (Vdf)?
I assume that there some structural consideration for choosing this number?
Flutter would be a consideration
Paul
On Tue, Aug 20, 2013 at 8:08 AM, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
[quote]--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Frans, As I understand it VNe (which for me is 165 kts) is 90% of Vdf or demonstrated flight diving speed so that I guess Europa  flew the prototypes at 183 kts to give the rest of us a bit of a margin for error. They probably thought that with the designed engines it wasn't likely that folk would want to  or be able to go much faster and design theory suggested that 183kts would be OK, always assuming of course that the plane was constructed properly. Regards, David Joyce,
