CJ Mag question
keithmckinley
PostPosted: Tue Aug 06, 2013 12:57 pm    Post subject: CJ Mag question Reply with quote
The two photos attached are of my left and right mags and the timing number stamped on them. I believe 23 to be the correct number although the other number on each mag looks prominent but in an area that looks like it may have been ground down.
Comments?
 Filesize:  490.01 KB
 Viewed:  5173 Time(s)
 Filesize:  428.05 KB
dsavarese0812(at)bellsout
PostPosted: Tue Aug 06, 2013 1:58 pm    Post subject: CJ Mag question Reply with quote
Keith,
Nothing attached.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Comments?
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=406084#406084
http://forums.matronics.com//files/left_mag_156.jpg
http://forums.matronics.com//files/right_mag_508.jpg
keithmckinley
PostPosted: Tue Aug 06, 2013 4:51 pm    Post subject: Re: CJ Mag question Reply with quote
that's weird, I can see the pics on the post.....I'll email them, but I hope they show so others can have a look too. Links are below:
K
wlannon(at)shaw.ca
PostPosted: Tue Aug 06, 2013 9:53 pm    Post subject: CJ Mag question Reply with quote
Keith;
I would suspect that 23 degs. is the correct number. That could change at
overhaul of the mag. depending on the spring tension, etc. of the new
auto-advance parts installed. The original 25 deg. markings should have
been obliterated to avoid confusion.
Re: The gear down restrictors; These should be at the bulkhead end of the
NORMAL gear down hose. If you have original Chinese manufactured hose the
restrictor end has a longer nut (to accommodate the restrictor!). I think
those are 0.5 mm (0.020") restrictors. However, I just got home from an
enjoyable (and well lubricated) flying club barbecue and my manuals are in
the hangar so all of the above is suspect to say the least.
Cheers;
Walt
keithmckinley
PostPosted: Wed Aug 07, 2013 6:39 am    Post subject: Re: CJ Mag question Reply with quote
Thanks Walt and Dennis!
Keith
dougsappllc(at)gmail.com
PostPosted: Wed Aug 07, 2013 9:07 am    Post subject: CJ Mag question Reply with quote
Restrictors:See CJ parts book volume #1 pages 280 thru 286, check down the Nomenclature column for items called "dampers" (items 17,33,40,).  Now refer back to page 279, find the item numbers 17, 33, and 40 in the pneumatic dwg to discover the correct location for installation.  Note that the "dampers" (AKA restrictors) have different part numbers, this is because they have differing sized holes in them.
I carry the blank restrictors in stock should you find you need them.
Doug
On Tue, Aug 6, 2013 at 10:50 PM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
[quote]--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
Keith;
I would suspect that 23 degs. is the correct number.  That could change at overhaul of the mag. depending on the spring tension, etc. of the new auto-advance parts installed.  The original 25 deg. markings should have been obliterated to avoid confusion.
Re:  The gear down restrictors;  These should be at the bulkhead end of the NORMAL gear down hose.  If you have original Chinese manufactured hose the restrictor end has a longer nut (to accommodate the restrictor!).   I think those are 0.5 mm (0.020") restrictors.  However, I just got home from an enjoyable (and well lubricated) flying club barbecue and my manuals are in the hangar so all of the above is suspect to say the least.
Cheers;
Walt
