lifting the housai
keithmckinley
PostPosted: Thu Jul 11, 2013 1:35 pm    Post subject: lifting the housai Reply with quote
All,
For what it's worth; Did a little research on changing engine mounts via past yak-list posts. Seems the best way to go is removing the generator and bolting in a plate with an eye hook (to lift the engine of course). There was a .PDF file with the measurements posted but I decided to put it in a CAD file. (autocad 2013). It's attached in 2D if anyone wants it.
The plate is 1/4" steel and the eyebolt is 3/8".
I got it cut on a cnc for 25 bucks.
gen_plate.dwg
 Filename:  gen_plate.dwg
 Filesize:  44.18 KB
 Downloaded:  289 Time(s)
Generator_Base_Plate.pdf
 Filename:  Generator_Base_Plate.pdf
 Filesize:  15.92 KB
 Downloaded:  296 Time(s)
dsavarese0812(at)bellsout
PostPosted: Thu Jul 11, 2013 2:41 pm    Post subject: lifting the housai Reply with quote
Nothing attached Keith.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 7/11/2013 4:35 PM, keithmckinley wrote:
All,
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=404499#404499
http://forums.matronics.com//files/gen_plate_106.dwg
keithmckinley
PostPosted: Thu Jul 11, 2013 6:10 pm    Post subject: Re: lifting the housai Reply with quote
Hi Dennis,
I see two files attached; a pdf file and the dwg file
I'll look into it.
Keith
