Fuel tank question
asarangan(at)gmail.com
PostPosted: Sat Jul 06, 2013 11:44 am    Post subject: Fuel tank question Reply with quote
After a one year pause, I am getting back into building. I am near the
stage of bonding the fuel tank into the CM. I read a lot of
discussions about tank swellings and cracking, so I am a bit
concerned.
Doing a google search, I came across a fuel tank mod document written
by Bud Yerly where he suggests using a cork pad in the fuselage to
support the tank. The details are a bit unclear to me, so I would like
solicit opinions from anyone who can give me some insights.
Thanks in advance!!
asc23111964(at)hotmail.co
PostPosted: Sat Jul 06, 2013 1:53 pm    Post subject: Fuel tank question Reply with quote
Hi Andrew,
One question,have you filled your fuel tank with a mix of fuels you are going to
use,and contained the tank with a sturdy wooden frame,and left it for at least 6 weeks?
The poly-propylene apparently expands by about 10 per cent
With the addition of fuel,this was in the old manual,but doesn't appear to be in the new one.
Could it be that tanks that have cracked haven't had this pre-soaking?
As for the cork at the bottom of the fuselage,sounds like a good idea,I'm sure that Bud can help you out.
Best Regards
Andy Cullum.
concerned.
Thanks in advance!!
jan_de_jong(at)casema.nl
PostPosted: Sat Jul 06, 2013 3:55 pm    Post subject: Fuel tank question Reply with quote
Andrew,
What I did.
1. make a cradle of 2, locally 3 bid:
http://www.europaowners.org/main.php?g2_itemId=89148
The idea is: good support without local bonding / deformation stresses
Put in the cradle / tank combination as the manual describes for the
bare tank:
http://www.europaowners.org/main.php?g2_itemId=89319
No glues / epoxies on the tank.
The treated tank (forgot which gas exactly) swells less, but now bonds
well to epoxies, making the unmodified original way of installing unwise.
2. put in lock-up EPP strips before putting the cradle / tank
combination in:
http://www.europaowners.org/main.php?g2_itemId=89154
http://www.europaowners.org/main.php?g2_itemId=89398
The idea is: minimize motion.
3. after bonding de cockpit into the canoe fill the space between cradle
and canoe with 2-component reasonably heavy polyurethane foam through
the fuel outlet access holes (calibrate the action beforehand to avoid
the tunnel and the exposed outboard tank surfaces)
This makes a port sandwich and a starboard sandwich - my version (Ron
Parigoris' rather) of Bud's cork.
The idea is: make the stresses still more distributed and the whole
installation stronger.
Jan de Jong
I have been on the verge of putting the top on for a while.
rparigoris
PostPosted: Sat Jul 06, 2013 4:37 pm    Post subject: Fuel tank question Reply with quote
Hi Andrew
"The details are a bit unclear to me, so I would like solicit opinions from anyone who can give me some insights."
Here's my attempt at keeping the fuel inside the tank:
http://www.europaowners.org/main.php?g2_itemId=28688
Scuffed tunnel, 3 BID, plastic sheet and injected foam to support.
Ron Parigoris [quote][b]
Duncan McFadyean
PostPosted: Sat Jul 06, 2013 11:43 pm    Post subject: Fuel tank question Reply with quote
The tanks are low density polyethylene, I understand. And they shrink back
over time when left empty (but not in my experience by as much as the
initial expansion). Fluoridated tanks may be different.
The Kitfox company understood this problem in 1990.
DMcF
PostPosted: Sun Jul 07, 2013 9:21 am    Post subject: Fuel tank question Reply with quote
Thanks for all the ideas. The problem, as I understand now, is the
attachment mechanism, and not necessarily the swelling. If the tank
can be supported without bonding its surfaces, then it should be able
to relieve the stresses as it expands and contracts. That's what I am
gathering from these discussions.
More puzzling is, it seems there is no agreement on what the tank is
made of. Just in the last few emails, I've heard Polypropylene, HDPE,
LDPE all mentioned, and Yerly's article says it is PTFE. I am somewhat
familiar with different polymers, and these are all very different
materials. I doubt it is PTFE because it is super expensive and
nothing will stick to it. I know a chemical test to identify different
polymers, but I would need a small chunk of the material. If I ever
figure that out, I will make sure to post my results here.
On Sun, Jul 7, 2013 at 3:43 AM, Duncan & Ami <ami-mcfadyean(at)talktalk.net> wrote:
DMcF
peterz(at)zutrasoft.com
PostPosted: Sun Jul 07, 2013 9:37 am    Post subject: Fuel tank question Reply with quote
When I had my tank and cobra (re/post) fluorinated by an industrial outfit, they confirmed it to be LDPE, fwiw.
The finished treated tank had a severe frosted finish.... an indication that the level of treatment was indeed higher than the factory's and I am hoping I will have less swelling issues down the road.
Pete
> DMcF
PostPosted: Sun Jul 07, 2013 10:13 am    Post subject: Fuel tank question Reply with quote
Thanks Pete. I am just about to embark on that route. I haven't called
them yet, but I am considering Fluoro Seal (http://www.fluoroseal.com)
if they are willing to take small jobs. They have a facility that is
within an hour driving from me.
Pete
>> DMcF
Fred Klein
PostPosted: Sun Jul 07, 2013 11:09 am    Post subject: Fuel tank question Reply with quote
Pete...and your kit # is...?...
thanks,
Fred
PostPosted: Sun Jul 07, 2013 11:25 am    Post subject: Fuel tank question Reply with quote
Oops...should have included it in my sig....
a239
Indeed it *was* factory fourinated, albeit i have to assume to a lower level
PostPosted: Sun Jul 07, 2013 11:26 am    Post subject: Fuel tank question Reply with quote
PS - the Europa factory obviously treats prior to finish cuts as well.....which pretty well negates the value of the process imho.
Pete
a239
On Jul 7, 2013, at 3:08 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
thanks,
Fred
tp://www.matronics.com/Navigator?Europa-List
cs.com
matronics.com/contribution
Fred Klein
PostPosted: Sun Jul 07, 2013 11:59 am    Post subject: Fuel tank question Reply with quote
Pete...your kind offer was moot for me in that my CM was already installed, w/ tank buried within of course...Fred
On Jul 7, 2013, at 12:24 PM, Pete wrote:
I am kinda surprised that there were no other takers a couple of years ago to split the min order cost ...... Since the per tank cost was a trivial $35 Smile
PostPosted: Sun Jul 07, 2013 1:18 pm    Post subject: Fuel tank question Reply with quote
So let me extend this offer to all. I plan to fluorinate my tanks
(#A178) sometime in the next month. As per Pete, the setup cost was
$300 and per unit cost is $35. If three or four of us can join, the
cost will become really trivial. But regardless, I plan to do it
anyway. The pictures I saw of swelling tanks makes me think this could
be worth thousands of dollars.
On Sun, Jul 7, 2013 at 3:58 PM, Fred Klein <fklein(at)orcasonline.com> wrote:
Smile
i36u42(at)gmail.com
PostPosted: Sun Jul 07, 2013 2:45 pm    Post subject: Fuel tank question Reply with quote
I am about to embark on a tank replacement. I don't have the tank yet but I'm interested, so contact me and tell me more. Brian Long
A124
On Sunday, July 7, 2013, Andrew Sarangan wrote:
[quote]--> Europa-List message posted by: Andrew Sarangan <[url=javascript:;]asarangan(at)gmail.com[/url]>
On Sun, Jul 7, 2013 at 3:58 PM, Fred Klein <[url=javascript:;]fklein(at)orcasonline.com[/url]> wrote:
> Smile
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
le, List Admin.
PostPosted: Mon Jul 08, 2013 11:00 am    Post subject: Fuel tank question Reply with quote
Hi Andrew,
If you do go ahead with it in the next month or two, and if you were interested (ie-if you had to ship further away than expected) I could ship my small 3Gallon tank to you in my Europa tank crate which you could then use, and when completed you could ship (at my cost of course) my little tank to an address in ogdensburg packaged simply in a cardboard box.
Just a thought. I could send you some pics of the crate. If I were to participate, I'd have to bring the tank to osh and am leaving on the 23rd Smile
Btw, great to hear you resumed you build! Funny how life keeps getting in the way.... Here too of course.
Pete
> Smile
PostPosted: Mon Jul 08, 2013 11:02 am    Post subject: Fuel tank question Reply with quote
Apologies to the list......email was meant for Andrew only...
Pete
On Jul 8, 2013, at 3:00 PM, Pete <peterz(at)zutrasoft.com> wrote:
Hi Andrew,
Pete
>> Smile
