Posted: Fri Jul 05, 2013 9:54 am Post subject: Master/Battery/Alt Field vs. Master/Battery and Alt Fiel |
At 11:34 AM 7/5/2013, you wrote:
I'm using the LR3C-14 external regulator and fuse blocks from B&C.
My field supply includes a fuse in my fuse block but I cannot pull
the fuse during flight.
then you have not followed instructions for the LR3C-14
for supplying field power through a breaker. This is to
accommodate the regulator's built in crowbar OV shutdown
system.
| Quote: | It sounds like I should either move the field supply to a breaker on
the panel that I can pull, or use the 3-position switch.
You need the breaker anyhow. After that, a 2 or 3 position
switch as you wish.
| Quote: | Another question. All of my 250 hours of flight are in a 1959 C172,
which has a generator. There is a master switch with two positions.
My question is under what conditions would one operate "battery only"?
Ground maintenance operations. Getting the
ATIS and Clearance delivery before starting
the engine. Shutting the generator/alternator
off for some kind of mis-behavior - voltage jumping
around but not so vigorously as to trip the OV
system.
mburbidg(at)gmail.com Guest
Posted: Fri Jul 05, 2013 10:28 am Post subject: Master/Battery/Alt Field vs. Master/Battery and Alt Fiel |
Bob,
Thanks. Glad I asked. I see the note about the breaker in bold. I had read the instructions at one point, and had ordered the 5 Amp breaker. So I have it. But I had not revisited the instructions when I started the wiring. It seems like a lot of non-TSO'ed equipment comes with almost no instructions and you get used to figuring it out on your own with help from forums and mailing lists. The B&C instructions are quite complete. A good reminder for me to use the instructions when they are supplied!
Michael-
On Jul 5, 2013, at 10:53 AM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
> I'm using the LR3C-14 external regulator and fuse blocks from B&C. My field supply includes a fuse in my fuse block but I cannot pull the fuse during flight.
system.
> It sounds like I should either move the field supply to a breaker on the panel that I can pull, or use the 3-position switch.
switch as you wish.
> Another question. All of my 250 hours of flight are in a 1959 C172, which has a generator. There is a master switch with two positions. My question is under what conditions would one operate "battery only"?
system.
