Subject: RotaxEngines-List: ground wire
jconnell(at)fmwildblue.co
PostPosted: Mon Jun 24, 2013 7:47 am    Post subject: Subject: RotaxEngines-List: ground wire Reply with quote
Hi,
My 582 brown wire is grounded to the engine. The ground wire from the Key West regulator is grounded to the frame. The engine is grounded to the frame with a braided strap – it needs to be heavy to handle the load when the starter is engaged. A lot of guys bring everything to a common ground on the aircraft. I did this in my RV-9A. See attached pictures for RV common ground and 582 ground strap.
All the best...
Joe
Time: 11:24:01 PM PST US
From: TURBO T <turbot(at)shaw.ca (turbot(at)shaw.ca)>
Where should the brown ground wire on a 532 be attached to ?
To airframe & engine block ?
Am in process of installing a Key West regulator that has a 12Volt DC plug that
is labeled to ground.
It should probably go to frame & block also, But would it be a good idea to connect
it to the brown engine wire also ?
 Filesize:  597.39 KB
 Viewed:  1932 Time(s)
 Filesize:  386.55 KB
