Fwd: RE: Routing electrical conduit
flying-nut(at)cfl.rr.com
PostPosted: Sun Jun 16, 2013 11:57 am    Post subject: Fwd: RE: Routing electrical conduit Reply with quote
I ran my conduit straight forward like picture #8 on both sides (step
drill works nice here) and made a side panel cover out of some thin
aluminum I had laying around. Some PEM nuts/screws hold the side panel
on. I don't use the long angled piece at all.
Linn
The attached photos are the only ones I can find that have more detail. The
conduit ends after it goes forward through the side rib lighting holes (the
ones where I installed the large grommets). Forward of that the runs just
use snap bushings like Van's has in his plans. I think I had to add one
additional hole on one side.
Note - there is no way to get all the wires and such past the panel bulkhead
just using the left side (with the supplied cover plate) per the planes. I
ran a 1" or so wire bundle up the inside of the last right side rib then
past the panel bulkhead in the side channel. I slightly enlarged the panel
notch that straddles the side channel for added clearance. I used some
plastic mesh conduit for this run. Most of it is hidden behind the little
side cover plate (photos #8 & #9).
Carl
 Filesize:  253.72 KB
 Viewed:  2243 Time(s)
 Filesize:  300.26 KB
 Filesize:  300.59 KB
 Filesize:  296.76 KB
johngoodman
PostPosted: Mon Jun 17, 2013 5:56 am    Post subject: Re: Fwd: RE: Routing electrical conduit Reply with quote
Why is this a separate thread?
