bob88
Posted: Thu Jun 13, 2013 9:48 pm Post subject: Routing electrical conduit |
Who has figured out how to route the conduit supplied in Van's electrical kit from front to the rear of baggage area? Other than the too small holes provided on the left and occupied by the P27 battery cable plus similar on the right, it appears to me that cutting holes in some fairly beefy looking structural members may be the only way. Am I missing something? OK to cut?
Posted: Fri Jun 14, 2013 3:10 am Post subject: Routing electrical conduit |
I didn't use the Van's electrical kit but here is how I ran the three
conduits on each side. Note - where these lines pass through the rear seat
pan or ribs I used an adhesive to make sure there was no relative motion
between the corrugated conduit and the aluminum. On the side lightning
holes I added large rubber grommets in the lighting holes.
I figured I needed two runs on each side, but added a third just in case. I
ended up using it. I have the two ADHRS modules mounted aft of the baggage
compartment as most do, so they have two 1/4" lines from the wing going aft
(pitot and AOA) and two going from aft up to the panel (pitot and static) as
I have a couple of analog gauges in the panel. All wire and tubing runs are
in the conduit including the #2 welding cable from both masters to the
starter solenoid.
Carl
RV-8A (sold last week)
RV-10, 95 hrs
348.21 KB |
9168 Time(s) |
293.31 KB |
9168 Time(s) |
Kelly McMullen
Posted: Fri Jun 14, 2013 4:58 am Post subject: Routing electrical conduit |
Avoid cutting structure. See Carl's response for one way to do it.
On Thu, Jun 13, 2013 at 10:48 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
| Quote: | --> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=402667#402667
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
Jim Berry
Posted: Fri Jun 14, 2013 9:46 am Post subject: Re: Routing electrical conduit |
I contacted Vans when I was doing this step, and they said it was OK to enlarge the holes in the bulkhead sides to 1".
Jim Berry
RV-10
johngoodman
Posted: Sat Jun 15, 2013 4:44 am Post subject: Re: Routing electrical conduit |
The real problem is that the convoluted tubing is very difficult to fish through when it has bends and turns. That's why you need so much conduit.
John
_________________ #40572 Phase One complete in 2011 |
trigo(at)mail.telepac.pt Guest
Posted: Sun Jun 16, 2013 8:57 am Post subject: Routing electrical conduit |
Carl
Indeed 1 image is better than a thousand words!... Thanks
However in your 2nd picture one cannot see how the 3 conduits pass through
the F-1004 C & D Center section bulkheads (the plans show only two 5/8"
holes), or did you stop the conduits there and only continued the electric
wires forward of those bulkheads?
Do you have a picture that shows forward of those bulkheads?
Carlos
johngoodman
Posted: Sun Jun 16, 2013 9:29 am Post subject: Re: Routing electrical conduit |
| trigo(at)mail.telepac.pt wrote: | Carl
I believe there were lightening holes - hence my comment about bends and turns.
John
Posted: Sun Jun 16, 2013 11:13 am Post subject: Routing electrical conduit |
The attached photos are the only ones I can find that have more detail. The
conduit ends after it goes forward through the side rib lighting holes (the
ones where I installed the large grommets). Forward of that the runs just
use snap bushings like Van's has in his plans. I think I had to add one
additional hole on one side.
Note - there is no way to get all the wires and such past the panel bulkhead
just using the left side (with the supplied cover plate) per the planes. I
ran a 1" or so wire bundle up the inside of the last right side rib then
past the panel bulkhead in the side channel. I slightly enlarged the panel
notch that straddles the side channel for added clearance. I used some
plastic mesh conduit for this run. Most of it is hidden behind the little
side cover plate (photos #8 & #9).
Carl
253.72 KB |
9087 Time(s) |
300.26 KB |
9087 Time(s) |
300.59 KB |
9087 Time(s) |
296.76 KB |
9087 Time(s) |
Posted: Sun Jun 23, 2013 3:20 am Post subject: Routing electrical conduit |
Thanks Carl
That is exactly what I needed to know!
Cheers
Carlos
