rv10rob(at)gmail.com Guest
Posted: Mon Jun 10, 2013 7:13 pm Post subject: Max RPM adjustment |
I have the standard MT governor on my RV-10 (IO-540-D4A5). I had the max RPM set to 2700 RPM initially, but over time it has been declining slowly, to the point that it's about 2640 on climbout now, at 2+ years and 200+ hours. Is that to be expected (i.e. I should just adjust the stop screw) or is this indicative of a problem requiring further investigation? The governor appears normal and in all other respects operates normally. Thanks...
-Rob
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
rv10flyer
Posted: Mon Jun 10, 2013 8:28 pm Post subject: Re: Max RPM adjustment |
My MT was set at 2700 and still runs between 2690-2710 depending on temperatures. I would ensure you are hitting the high rpm stop when prop knob is fully forward and ensure the adjustment screw has not moved. I doubt it is normal wear and tear. Call MT. They may just tell you to readjust. Let us know what you find out.
_________________ Wayne G. |
Posted: Mon Jun 10, 2013 9:20 pm Post subject: Max RPM adjustment |
I'd back the screw out a bit and see if you get the RPM back. Â Make sure you have full travel to the screw. Â If you get to the screw but don't get the RPM back then I'd think your pitch stop inside the hub has changed but that seems very unlikely. Â Try the simple adjustment first and like Wayne said if you feel calling MT is helpful then by all means do that too.
Dave Saylor
831-750-0284 CL
On Mon, Jun 10, 2013 at 8:13 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote] I have the standard MT governor on my RV-10 (IO-540-D4A5). I had the max RPM set to 2700 RPM initially, but over time it has been declining slowly, to the point that it's about 2640 on climbout now, at 2+ years and 200+ hours. Is that to be expected (i.e. I should just adjust the stop screw) or is this indicative of a problem requiring further investigation? The governor appears normal and in all other respects operates normally. Thanks...
-Rob
Rob Kochman
Woodinville, WA
tp://forums.matronics.com
| [b]
Kellym
Posted: Mon Jun 10, 2013 9:23 pm Post subject: Max RPM adjustment |
Only make very small adjustment at a time. You do NOT want a prop
overspeed. You want to achieve about 2650-2670 static rpm on the ground,
which will get you darn close to 2700 on takeoff roll.
On 6/10/2013 10:19 PM, Dave Saylor wrote:
| Quote: | I'd back the screw out a bit and see if you get the RPM back. Make
sure you have full travel to the screw. If you get to the screw but
has changed but that seems very unlikely. Try the simple adjustment
Dave Saylor
831-750-0284 CL
-Rob
Rob Kochman
Woodinville, WA
Checked by AVG - www.avg.com
KCHD |
flysrv10(at)gmail.com Guest
Posted: Tue Jun 11, 2013 12:03 am Post subject: Max RPM adjustment |
Plugs good? Timing good? Mags perfect? Air filter clean? Plenum sealed?
I would start elsewhere for the cause of the RPM drop.
do not archive.
On Jun 10, 2013, at 11:13 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]I have the standard MT governor on my RV-10 (IO-540-D4A5). I had the max RPM set to 2700 RPM initially, but over time it has been declining slowly, to the point that it's about 2640 on climbout now, at 2+ years and 200+ hours. Is that to be expected (i.e. I should just adjust the stop screw) or is this indicative of a problem requiring further investigation? The governor appears normal and in all other respects operates normally. Thanks...
-Rob
Rob Kochman
Woodinville, WA
| [b]
Kelly McMullen
Posted: Tue Jun 11, 2013 5:38 am Post subject: Max RPM adjustment |
Excellent suggestions. Governor and prop settings rarely drift around. Lack of rpm usually means some loss of power, which usually implies either fuel or air are restricted or not fired at exactly the right time. Usual suspects are fouled plug(s), timing has drifted(normal with points wear), partially plugged injector, etc.
On Tue, Jun 11, 2013 at 1:03 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
[quote]Plugs good? Timing good? Mags perfect? Air filter clean? Plenum sealed?
do not archive.
A&P/IA, EAA Tech Counselor
KCHD |
rv10flyer
Posted: Tue Jun 11, 2013 6:39 am Post subject: Re: Max RPM adjustment |
I think that applies to a fixed pitch prop or CS on the ground. Notice he said on climbout. As soon as you are rolling down the runway our prop pitch starts increasing. If he was developing 5% less power, his pitch would just start increasing later down the runway but should have still reached 2700. If he was developing less power than that then he should notice MP, FF, EGT and performance changes too. I usually get about 26.5 gph FF and 1250-1275 EGT's and on takeoff.
I keep pictures on my I pad/I phone of climb and cruise numbers from my 1st flights and occassionally after to reference back to. This will help me to troubleshoot if things slowly change. I also wrote all numbers down during most phase 1 flights.
