RU check valves removed from pop off valve assembly
viperdoc(at)mindspring.co
PostPosted: Fri Jun 07, 2013 7:31 am    Post subject: RU check valves removed from pop off valve assembly Reply with quote
These are the check valves after removal from the pop off assembly.
Doc
 Filesize:  35.49 KB
 Viewed:  1461 Time(s)
mark.bitterlich(at)navy.m
PostPosted: Fri Jun 07, 2013 12:10 pm    Post subject: RU check valves removed from pop off valve assembly Reply with quote
CJ6 checks valves are different than YAK check valves. This is not the
pop off valve assembly.
PostPosted: Sat Jun 08, 2013 5:04 am    Post subject: RU check valves removed from pop off valve assembly Reply with quote
If not then what is it?
Doc
On Jun 7, 2013, at 3:08 PM, "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil> wrote:
