galinhdz(at)gmail.com Guest
Posted: Sun May 05, 2013 6:46 pm Post subject: Leftover "stuff" from new instrument panel |
Since I finished my new glass panel I now have a lot of leftover "stuff" available. These items are: UMA Electronic Tach with Sender ACS Oil Temp Gauge with sensor ACS Oil Pressure gauge with sensor WESTACH DC Volt Meter WESTACH DC Amp Meter with 40A shunt WESTACH EGT with 4 position selector switch WESTACH CHT with 4 position selector switch UMA Fuel pressure gauge with sensor BUSSMAN 20 circuit fuse block NFLITE's 14v low voltage annunciator VSI (BC-2A, SN 0831) DG (RCA-11A-8, SN 99E0303G) ASI (16-311-202D, SN A7209) RAPCO Vacuum System to include: 2ea Vacuum pumps (RA215CC) Filter (RA-D9-18-1) Regulator (RA2H3-23) Misc hoses New (never installed) Hobbs Meter Garmin 430 connector plugs Garmin x96 Power Data Cables (1 new still in original packaging) 2ea ZYTRON Lab Main Bus Switches (both new still in original packaging) Switches ACS A-510-2 Starter switch (with red dot) DP/DT OFF/ON/MOM switch (used for fuel pump & primer power) DP/DT ON/OFF/ON switch (used for GPS data selector) SP/ST push ON/OFF switch (illuminated) Cessna Split Master/Alternator switch (S-1994-1-1, SN 9843) Potter & Brumfield 5A circuit breaker 10 ohm, 1.12A rheostat (Panel dimmer) DYNON SV-HARNESS-D37 (NEW) SV-NET-15CP (NEW) DYNON D25 Male connector with pins (NEW) D10/D6 Flush Mount Bracket (NEW) SV-NET-TEST cables (2ea NEW) 1ft USB extender cable (2ea NEW) DB9 Male/male gender changer (2ea NEW) iPad1 RAM Mount, Otter Box and ZAGG carrier 37 pin plug with 40 male and 40 female pins (NEW) If you are interested in any of these items, send me an offer and I will more than likely accept it. You can find photos of the actual items at: http://s1175.photobucket.com/user/Puertoricoflyer/library/Items%20For%20Sale?sort=4&page=1 I also have 3ea Scale 4 Planes (http://scales4planes.com/gpage6.html) TCS-JJ electronic platform scales (carrying case NOT included). These can weigh up to 1500lbs each (so you can weigh an airplane up to 4500lbs) with the longer molded cables, battery operation, AC power plugs, display mounting bracket and with non slip surface. $300.00 ea or all 3 for $850.00 (shipping is extra). You can see one of the actual scales at: http://s1175.photobucket.com/user/Puertoricoflyer/media/Items%20For%20Sale/AirplaneScale_zps4d04d5c3.jpg.html?sort=4&o=1
Galin
