etekberg(at)gmail.com Guest
Posted: Mon Jun 12, 2006 4:52 am Post subject: Experimental IFR w/o a certified GPS or looking for a copy o |
I work on WAAS for the FAA and have the MOPS (229c) on pdf. There is lots of good information in the document useful for building a WAAS receiver, but I don't think you'll find what you are looking for there. The word experimental occurs only 1 time and in the context of "findings based on experimental data".
Eric
RV-10 #583 - empennage
On 6/11/06, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote: Quote: | --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
I recently read an article posted on Direct2. website
http://www.direct2avionics.com/pdfs/Using_GPS_for_IFR_flight.pd by a
Phd CFII that concludes that for EXPERIMENTAL aircraft, it was not
necessary for the aircraft to be equipped with a CERTIFIED GPS receiver
to legally file and fly IFR, PROVIDED that you, the pilot/mfg can
evaluate the GPS functionality, and find it provides all of the
necessary pilot input (as defined in the TSO) for IFR flight.
This sounded like it was worth looking into. I verified this opinion
with a competitor of Direct2. So off I go to study TSO-C146 the Standard
document for WAAS GPS, unfortunately there is nothing in the document
regarding functional requirements other than a reference to:
RTCA/DO-229B (which I learned has since been superceeded w/
RTCA/DO-229C). Another Google search reveals that this document is
available but with a cost which ranged from $108-370 per copy.
Does anyone know of a 'library' where this document could be 'rented' or
checked-out. a couple hundred bucks is a steep price for someone just
investigating an idea/thought.
Deems Davis # 406
Fuse
http://deemsrv10.com/
Tdawson(at)avidyne.com Guest
Posted: Mon Jun 12, 2006 5:07 am Post subject: Experimental IFR w/o a certified GPS or looking for a copy o |
Yeah, in general, TSOs are really equipment specs, not operational specs, and TSO’ed equipment just helps with the certification of an aircraft installation by STC or TC. (in fact, certified aircraft can even get away with non-TSO equipment, if they can convince the FAA to allow it under their TC.)
For experimental aircraft, in general, TSOs are not really necessary, since there is no STC or TC. (just look at all of us using GRT or other “non-TSO’ed” equipment for engine instruments, and the FAA doesn’t ask us to prove they meet some spec.)
However, the FAA may have blurred lines by issuing ACs that blend operational and equipment requirements. (specific to IFR GPS ops, etc.)
Isn’t FAA certification a wonderfully transparent and easy process?
TDT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Ekberg
Sent: Monday, June 12, 2006 8:50 AM
Subject: Re: RV10-List: Experimental IFR w/o a certified GPS or looking for a copy of RTCA/DO-229C
Eric
Deems Davis # 406
Fuse
billderou(at)yahoo.com Guest
Posted: Mon Jun 12, 2006 8:51 am Post subject: Experimental IFR w/o a certified GPS or looking for a copy o |
I have two questions regarding blending experimental equipment with certified equipment.
In July 2003 I ordered an RV-10 kit and began designing out all vacuum-based components ending up with a complete IFR glass panel. The PFD/EFIS was implemented from scratch.
The panel is highly integrated and the main pieces are:
1) Garmin 430 and 330.
2) Own display computer driving a 10.4" sunlight rated industrial LCD.
3) Own calibrated air data computer with high sensitivity.
4) Commercial 360 degree, accurate solid state gyro pack.
5) Own black box to convert all the discretes and analog outputs from the Garmin 430 to packets.
6) Good IFR Tru-Trak 2-axis autopilot.
All the above has been tested, prototyped and installed in our RV-10. First flight will occur in July.
My two questions are:
Since I have pulled the Garmin Glideslope/Localizer CDI and annunicators into my
experimental display does this negate my legal ability to fly IFR?
Since my experimental air data computer is supplying pressure altitude to the
Garmin 330 transponder does this satisfy all VFR & IFR requirements? I will
have a licensed avionics shop perform a standard pitot/static & transponder
certification.
Bill DeRouchey
N939SB, RV-10 kit #40029
billderou(at)yahoo.com (billderou(at)yahoo.com)
the requiRe: the blending operational and equipment requirements as mentioned by Tim Dawson-Townsend
Tim Dawson-Townsend <Tdawson(at)avidyne.com> wrote:
Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } Yeah, in general, TSOs are really equipment specs, not operational specs, and TSO’ed equipment just helps with the certification of an aircraft installation by STC or TC. (in fact, certified aircraft can even get away with non-TSO equipment, if they can convince the FAA to allow it under their TC.)
TDT
To: <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />rv10-list(at)matronics.com
Subject: Re: Experimental IFR w/o a certified GPS or looking for a copy of RTCA/DO-229C
Eric
Deems Davis # 406
Fuse
Posted: Mon Jun 12, 2006 9:59 am Post subject: Experimental IFR w/o a certified GPS or looking for a copy o |
Sounds like you’re good to go to me. It’s not TSO’ed equipment, but it does the necessary functions. To impress the inspector, you could even borrow a Nav radio test set and drive the Garmin with some simulated VOR/LOC and GS signals to verify your deviation indicator.
TDT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Monday, June 12, 2006 12:50 PM
Subject: RE: RV10-List: Experimental IFR w/o a certified GPS or looking for a copy of RTCA/DO-229C
certification.
Bill DeRouchey
TDT
Eric
Deems Davis # 406
Fuse
dlm46007(at)cox.net Guest
Posted: Mon Jun 12, 2006 12:36 pm Post subject: Experimental IFR w/o a certified GPS or looking for a copy o |
Perhaps I don't understand but has anybody been questioned by the FAA or ATC about whether they have TSOed Class A1 equipment on board and operational?
