FAA Special Review Team final report.... Have questions...
psm(at)att.net
PostPosted: Sun May 26, 2013 5:35 pm    Post subject: FAA Special Review Team final report.... Have questions... Reply with quote
Guys,
Don't forget the AMD performance numbers are based on a Continental
engine which weighs about a hundred pounds more than a Rotax or Jabiru.
I suspect you will find the cruise speed for the Continental is around
100, Rotax around 110, and Jabiru around 120 - all in KIAS.
I personally don't have a ballistic 'chute and don't want one. While
they have an average record of actually helping they can also kill you.
I know of at least one case where the plane was on fire, the pilot
pulled the big chute and all aboard roasted before reaching the ground.
Paul
On 5/26/2013 5:59 PM, SIDESLIP wrote:
Barry;
Thanks! That's the one I've based my numbers off. Mine are slightly off.
Vc should be called VNO. But whatever. So 108kts Vno
I'll edit my numbers.
Thanks!
Chad
C-GYXQ. 912ULS. 601XL-B
http://forums.matronics.com/viewtopic.php?p=401397#401397
