tmckeon79(at)hotmail.com Guest
Posted: Tue Apr 30, 2013 7:58 am Post subject: Engine hoist ring on Propeller shaft |
Some time ago I purchased a stock Housai engine to replace the one I had damaged. The installation is going smooth but I am having one small issue. On the Propeller drive shaft is a hoist ring that I and the local maintenance personell at my field cannot figure out how to remove. Does anyone know of a trick or technique to get this off? A picture is attached of what I'm talking about.
Tom
1.08 MB |
2940 Time(s) |
Dale
Posted: Tue Apr 30, 2013 10:09 am Post subject: Re: Engine hoist ring on Propeller shaft |
screws on. no secret . Might need to put a rod through it and tap it . Right turn to tighten, Left to loosen . You might want to heat it up also with a flaming wrench. ( heat gun or propane soldering tank )
