		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Sat Apr 13, 2013 12:33 pm    Post subject: Rudder Pedal Travel |
				I did a search but could not find this info.  I'm trying to decide where to set my rudder pedals and need to know how much they travel forward from the neutral position when fully deflected (nose gear and rudder cables attached.) With this info I'll be able to adjust for maximum legroom without worrying about running out of rudder or ground steering.
 Thanks!
 Tim
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		mhubel
				 Posted: Sat Apr 13, 2013 6:26 pm    Post subject: Rudder Pedal Travel |
				Tim,
      I take it you don't have cables to the rudder yet as there is a
 specification for rudder travel. I will be at the airport tomorrow and
 can look at mine.
 On 04/13/2013 4:33 PM, Tim Juhl wrote:
  Thanks!
  Tim
  ______________
  CFII
  Champ L16A flying
  Wing modifications done - back working on the fuselage
  http://forums.matronics.com/viewtopic.php?p=398555#398555
 Mark Hubelbank
 NorthEast Monitoring
 2 Clock Tower Place
 Suite 555
 Maynard, MA, 01754 - USA
 mhubel(at)nemon.com
 978-443-3955
  _________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
		Tim Juhl
				 Posted: Sat Apr 13, 2013 6:43 pm    Post subject: Re: Rudder Pedal Travel |
				You are correct.  I will be installing the nose strut and making rudder cables in the next few weeks.
 Tim
CFII
Champ L16A flying
		dalemed
				 Posted: Sun Apr 14, 2013 7:51 am    Post subject: Re: Rudder Pedal Travel |
				2" should do it (neutral to firewall)
 Dale
  _________________ Dale
Zenith Zodiac CH650 |
		mhubel
				 Posted: Wed Apr 24, 2013 6:07 pm    Post subject: Rudder Pedal Travel |
				Tim,
      I expect you have already received this  from someone but I just
 found the note. On mine, with both peddles at the same position, they
 are 6 1/8 inch from the aft side (seat side) of the peddle bar to the
 firewall.
      At the extreme rudder deflection, the distances are 8 5/8 and 4 1/4
 inches for the two peddles. This may be slightly closer to the firewall
 than some would do it. I have a tall friend who flies with me and I
 moved the peddles as far forward as possible.
 On 04/13/2013 10:26 PM, Mark Hubelbank wrote:
  	  | Quote: | 	 		   Tim,
  can look at mine.
 > ground steering.
 > Thanks!
 > Tim
 > ______________
 > CFII
 > Champ L16A flying
 Mark Hubelbank
 2 Clock Tower Place
 Suite 555
 mhubel(at)nemon.com
 978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
		Tim Juhl
				 Posted: Thu Apr 25, 2013 5:50 am    Post subject: Re: Rudder Pedal Travel |
				Mark,
 See if I have this right - from neutral, your rudders move a little more than two inches in each direction?  That corresponds to other info I've gotten.  I may set my neutral even closer to the firewall than you.  My experience is limited but I could have used a bit more room in the two Zodiacs I've flown in.
 Thanks!
 Tim
CFII
Champ L16A flying
