robin(at)PaintTheWeb.com Guest
Posted: Fri Apr 12, 2013 1:39 pm Post subject: G3X certified WAAS GPS |
Save thousands on GPS 400W installed with G3X
January 9, 2013 - posted in In the Air,
[img]cid:image001.png(at)01CE378B.82855100[/img]If you own a G3X flight display system or if you're planning to purchase a G3X, you can take advantage of special reduced pricing on an IFR-certified GPS. Now through 12/31/13, the GPS 400W is available for just $3,995 when installed with a G3X system.
Having a WAAS-certified navigator, like the GPS 400W, allows the pilot to fly GPS and LPV approaches. It also provides the WAAS position source needed to comply with the requirements for ADS-B.
76.6 KB |
2888 Time(s) |
5.63 KB |
2888 Time(s) |
