Nose Gear
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
ghf4986(at)gmail.com
PostPosted: Sun Apr 07, 2013 3:06 pm    Post subject: Nose Gear Reply with quote
Sent from an IPad
After checking my nose gear, I decided to cut the collar off and
machine a 4130 by 3/4 steel rod to fit the nose gear down leg at the
proper angle. Then machined the rod down to 5/8 to go through the
yoke and threaded the end past the yoke, then welded the rod in place.
I am hoping this will work well. Without the collar the entire pin
and weld is visible. I also found that the cast aluminum yoke had
stretched and was developing excessive play. Fortunately I have a
spare aluminum yoke.
Dennis.
AD pulsar XP
N375CM
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
gregsmi
PostPosted: Sun Apr 07, 2013 3:20 pm    Post subject: Nose Gear Reply with quote
Dennis, we found that the 4130 had a hardness of 90ksi while the bolt used in the original was rated at 130ksi. Keep a lose eye on it and please keep us informed of how things are going.
Greg
In a message dated 4/7/2013 6:07:11 P.M. Central Daylight Time, ghf4986(at)gmail.com writes:
--> Pulsar-List message posted by: Dennis Adams <ghf4986(at)gmail.com>
Sent from an IPad
Dennis.
AD pulsar the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
PostPosted: Sun Apr 07, 2013 4:05 pm    Post subject: Nose gear Reply with quote
In my previous note I used the wrong steel specification, I meant to
type 4340 steel. This is what I used for my nose pin.
Dennis
Sent from an IPad
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
