CJ fuel system bypass line question
samira.h(at)shaw.ca
PostPosted: Sun Mar 31, 2013 4:33 pm    Post subject: CJ fuel system bypass line question Reply with quote
As you probably all know in a Nanchang there
is a bypass line parallel to the fuel check-valve
and wobble pump (please see attached picture).
I was always under the impression that the
function of above mentioned line is to prevent
over-pressurizing of the fuel system by the
use of the manual wobble pump.
Any opinion on this subject is highly appreciated.
cheers
Elmar
 Filesize:  442.18 KB
 Viewed:  894 Time(s)
