Rear Windows
jeff(at)westcottpress.com
PostPosted: Thu Mar 28, 2013 8:49 am    Post subject: Rear Windows Reply with quote
Hi Vernon,
I'd do a little bit of everything... sand down the inside of the joggle, build up the rail with flox and feather back in to meet the door. I my case, I built up with flox and micro to meet the window, overlapped the window with glass tape and transitioned back in to the door (pic attathed).
Jeff Carpenter
40304... getting there.
On Mar 28, 2013, at 9:13 AM, Vernon Franklin wrote:
Does everyone's rear windows stick out from the lip this much? Picture attached.
Is this area going to built up to make it flush when the windows get installed? Or should I sand down and rebuild the lip to push the window into the fuselage more?
<image.jpeg>
Vernon Franklin
 Filesize:  208.79 KB
 Viewed:  2274 Time(s)
davidsoutpost(at)comcast.
PostPosted: Thu Mar 28, 2013 9:07 am    Post subject: Rear Windows Reply with quote
rleffler
PostPosted: Thu Mar 28, 2013 9:14 am    Post subject: Rear Windows Reply with quote
I know of one instance in which the wrong windows were shipped from the Van's supplier. They were too thick.
The more common reason is the there is a flat spot on the canopy near the window. While not a 100% sure, I think they all come this way. Check that curve with you door on. You may find that you have to build up you canopy which may also resolve you window problem.
Another metric to check is to see if the relief area around the window perimeter is a constant depth.
Are both windows the same?
On Mar 28, 2013, at 12:13 PM, Vernon Franklin <vernon.franklin(at)gmail.com> wrote:
<image.jpeg>
Vernon Franklin
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
dave.saylor.aircrafters(a
PostPosted: Thu Mar 28, 2013 9:43 am    Post subject: Rear Windows Reply with quote
That looks pretty normal. The joggle isn't quite deep enough. You
can build it up to be flush with the window. I recall seeing that a
few times before.
Dave Saylor
831-750-0284 CL
On Thu, Mar 28, 2013 at 9:13 AM, Vernon Franklin <vernon.franklin(at)gmail.com>
attached.
Vernon Franklin
partner14
PostPosted: Thu Mar 28, 2013 10:39 am    Post subject: Rear Windows Reply with quote
I measure the thickness of the window all the way around.... it varied by quite a bit. So I sent it back to Van's and they sent me another one... much better.... but as everyone has told you, do a little bit of everything.... especially glassing around the window... it will keep the paint from cracking later.... hopefully.
Don Mc
--- On Thu, 3/28/13, Bob Leffler <rv(at)thelefflers.com> wrote:
Subject: Re: Rear Windows
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Thursday, March 28, 2013, 12:14 PM
--> RV10-List message posted by: Bob Leffler <[url=/mc/compose?to=rv(at)thelefflers.com]rv(at)thelefflers.com[/url]>
On Mar 28, 2013, at 12:13 PM, Vernon Franklin <[url=/mc/compose?to=vernon.franklin(at)gmail.com]vernon.franklin(at)gmail.com[/url]> wrote:
<image.jpeg>
http://www.matronics.com/Navigatsp; - MATRONICS WEB FOt; http://forums.sp; - List Contribution Web Sbsp; > ht
Don A. McDonald
40636
