Panel design
trigo(at)mail.telepac.pt
PostPosted: Wed Mar 20, 2013 4:35 am    Post subject: Panel design Reply with quote
Guys
Not directly related with RV-10’s, but I wonder if somebody knows about a free software to help design the instrument panel layout.
Carlos
johngoodman
PostPosted: Wed Mar 20, 2013 4:50 am    Post subject: Re: Panel design Reply with quote
A large sheet of paper cut to the size of the panel would work better and doesn't have a learning curve. Number 2 pencils are pretty cheap.
jesse(at)saintaviation.co
PostPosted: Wed Mar 20, 2013 5:21 am    Post subject: Panel design Reply with quote
I use TurboCAD software. It is relatively inexpensive. If you found some free CAD software that would allow for 2D design and output to DWG or DXF format, that should work well. Then you just need to draw up your instruments and your radio stack and work on the arrangement on the panel with the constraints behind the panel taken into account.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Mar 20, 2013, at 8:35 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Guys
Carlos
style="color: purple; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
purple; text-decoration: underline; ">http://forums.matronics.com
style="color: purple; text-decoration: underline; ">http://www.matronics.com/contribution
robin(at)PaintTheWeb.com
PostPosted: Wed Mar 20, 2013 6:16 am    Post subject: Panel design Reply with quote
I used XPanel. Its not free but IMHO its worth the $80.00. It saves much time with the RV blank panel templates pre-designated plus all the avionics I needed already in the system. Simple enough to learn and use.
If you want free; Google Chrome has a free CAD style app you can download for free and use to lay out a kitchen, backyard or panel. Just go to the Chrome app store. Sorry on my tablet now or would send you a link.
Robin
Carlos Trigo <trigo(at)mail.telepac.pt> wrote:
Guys
Carlos
ics.com
PostPosted: Wed Mar 20, 2013 7:07 am    Post subject: Panel design Reply with quote
I know John, I did it several times many moons ago ...
But having a simple to use software, which has the actual digital pictures of the various equipments that can be dragged with the mouse to the panel is really that simple. No learning curve at all.
By the way, I do remember using, not so long ago, one called “epanelbuilder” or something like that, that I can’t seem to find now. Anyone knows about this?
Carlos
glastar(at)gmx.net
PostPosted: Wed Mar 20, 2013 7:14 am    Post subject: Panel design Reply with quote
On my Glastar I did the paper setup first then used an acrylic 3mm
"sheet" to mount them, so I could see what is behind.
Werner
#40572 Phase One complete and flying.
http://forums.matronics.com/viewtopic.php?p=396641#396641
PostPosted: Wed Mar 20, 2013 7:54 am    Post subject: Panel design Reply with quote
Werner
For the actual layout in the panel, in order to cut the holes, I will use that technique or something similar.
What I am looking right now is to begin from scratch, trying to figure out what goes where, what fits and what don’t …. Initial approach to the layout
Carlos
kearney
PostPosted: Wed Mar 20, 2013 8:11 am    Post subject: Panel design Reply with quote
Carlos
You can use Panel Planner to do the layout. It has templates that also have slave requirements for behind the panel.
You can drag and rearrange until you are happy with the result.
Cheers
Les
On 2013-03-20, at 9:53 AM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Werner
Carlos
rv10flyer(at)live.com
PostPosted: Wed Mar 20, 2013 9:27 am    Post subject: Panel design Reply with quote
If you own Photoshop, or visio or can locate a free app that can read the Vans panel than should be able to grab pictures off of brochures or on the web of your planned avionics and place it on the Vans panel. I think I measured all the dimensions than made the templates in Visio once I worked out the spacing issues I put it all in photoshop to see how it all looked.
Sent: Wednesday, March 20, 2013 8:53 AM
Subject: RE: Re: Panel design
Werner
Carlos
Gordon Anderson
PostPosted: Wed Mar 20, 2013 10:11 am    Post subject: Panel design Reply with quote
Hi Carlos,
If you're after 2D CAD software, you can download Dassault DraftSight free. This is not a "panel planner" in the sense of showing the instruments and avionics, but more of a "hole planner" and something you can then use to CNC cut the panel.
Attached is the .dwg file for my RV-10 panel (in development).
Gordon
On Mar 20, 2013, at 1:35 PM, Carlos Trigo wrote:
Guys
Carlos
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
RV-10_GDA_PANEL_V1.dwg
 Filename:  RV-10_GDA_PANEL_V1.dwg
 Filesize:  72.51 KB
 Downloaded:  524 Time(s)
flying-nut(at)cfl.rr.com
PostPosted: Wed Mar 20, 2013 11:00 am    Post subject: Panel design Reply with quote
One thing to keep in mind ..... equipment mounting data can be had from the manufacturer but may not include the dimensions of the bezel ..... which you need to know when mounting items close together.
Linn
Werner
Carlos
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Werner Schneider
Sent: quarta-feira, 20 de Março de 2013 15:14
Subject: Re: Re: Panel design
--> RV10-List message posted by: Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)>
On my Glastar I did the paper setup first then used an acrylic 3mm "sheet" to mount them, so I could see what is behind.
Werner
--> RV10-List message posted by: "johngoodman"
--> <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
Checked by AVG - www.avg.com
03/20/13 [b]
Bob Turner
PostPosted: Wed Mar 20, 2013 11:32 am    Post subject: Re: Panel design Reply with quote
Don't forget to sit in the real airplane, in the actual flying seating position, and look at paper cutouts on the panel. You can check the ease and feel as you reach for things; that nothing important is hidden under the glare shield; and that important things like the PFD are in focus (important for me as I wear bifocals!).
Bob Turner
RV-10 QB
aircraftspecialty(at)gmai
PostPosted: Wed Mar 20, 2013 12:33 pm    Post subject: Panel design Reply with quote
We will be making an announcement once we get the website fully updated. We are planning on videos of the whole process.
But for now, if you are interested, we offer Cnc design, panel cutting, powdercoat and screen labeling of panels at incredible prices. We will make an announcement once we have the full site up, but go to
www.aircraftspecialty.com
for more Information.
Or, please email us at
steve(at)aircraftspecialty.com (steve(at)aircraftspecialty.com)
We have already started designing and cutting panels and would be happy to work with you.  We are home builders and will be happy to help you with all the little ins and outs of getting your panel perfect.
Have a great day
Steve
On Mar 20, 2013, at 10:06, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
Dick Sipp
PostPosted: Wed Mar 20, 2013 3:38 pm    Post subject: Panel design Reply with quote
In addition to Bob's excellent advice, when it comes to switch layout; think
about a logical order of switch usage i.e. going down a row rather than
jumping around when running the checklist.
Also consider where the important autopilot power switch and fuel pump
switches will be; these should readily available and easily reached.
Finally the primary flight display should be as close to centered in front
of the pilots head as possible. Looking cross cockpit at the flight display
will bug you. Stay away from unconventional arrangements; most certified
panels are similar for a reason, they work. A good conventional panel will
add much to your enjoyment of the airplane and add to resale value.
Dick Sipp
470 hours
Dick Sipp
cooprv7(at)yahoo.com
PostPosted: Thu Mar 21, 2013 4:21 am    Post subject: Panel design Reply with quote
One other tip in case it helps. I used the plastic covers for switches to make them easily identifiable and layer them in an order that makes sense to me. I used red for power (battery and alternator), green for avionics (cause they cost a lot of money), blue for fuel pump, white for lights and yellow for pitot heat. This way a quick glance and I'm ready for any phase be it engine start, takeoff or shutdown.
Marcus
On Mar 20, 2013, at 7:37 PM, "Dick & Vicki Sipp" <rsipp(at)earthlink.net> wrote:
In addition to Bob's excellent advice, when it comes to switch layout; think about a logical order of switch usage i.e. going down a row rather than jumping around when running the checklist.
Also consider where the important autopilot power switch and fuel pump switches will be; these should readily available and easily reached. Finally the primary flight display should be as close to centered in front of the pilots head as possible. Looking cross cockpit at the flight display will bug you. Stay away from unconventional arrangements; most certified panels are similar for a reason, they work. A good conventional panel will add much to your enjoyment of the airplane and add to resale value.
Dick Sipp
470 hours
Dick Sipp
