gcomfo(at)tc3net.com Guest
Posted: Sun Mar 17, 2013 10:24 am Post subject: radio noise |
Bob, et al:
Been a long time since I posted to any list but this time I have a question. My RV-4 com radio when neither transmitting nor receiving presents noise to the headsets that is unacceptable. An incoming signal of reasonable strength comes through clearly and the transmit has been ok, but one pilot described my signal as weak. The radio is a Walter Dittel FSG71 and has been checked by Peninsula Avionics and found to be ok, or at least not found to be defective. The tech type that worked on it suggested checking the antenna for good base contact with the metal skin. I removed the antenna thinking that there might be corrosion (20 years in service) and found the faying surfaces to be coated with oil but with bright metal on both sides. I have been through all the connections and find no anomalies. Headset jacks are insulated with clean contacts. The Sigtronics intercom is wired through the radio and when the radio is turned off, works fine.
Questions: Would the presense of oil compromise the antenna performance and if so, would dielectric grease serve to improve it?
Is there a failure mode for the antenna itself that could result in the above symptoms and how could one tell?
Thank you very much.
We should talk some time.
Gordon Comfort
N363GC
Posted: Sun Mar 17, 2013 11:33 am Post subject: radio noise |
Bob, et al:
Gordon Comfort
N363GC
Posted: Sun Mar 17, 2013 12:57 pm Post subject: radio noise |
| Quote: | At 01:24 PM 3/17/2013, you wrote:
| Quote: | Bob, et al:
It HAS been a long time my friend. Hope you and Marge are
both well . . .
| Quote: | My RV-4 com radio when neither transmitting nor receiving
Probably not if the screws were tight.
| Quote: | Is there a failure mode for the antenna itself that could result in
Probably not for the antenna but certainly for the coax.
Connectors on both ends are solidly attached? Do you have
access to an SWR meter?
Do I interpret your words to mean that only one pilot
has complained about your signals being 'weak'?
Listener interpretation of signal quality is an iffy
sort of thing. Somebody with a rich history in radio
communications, particularly AM would have an 'ear' for
various quality issues which go to modulation depth,
distortions, and overall signal strength. In other words
have a grey bearded ham listen to your signal on a hand
held from a mile or so away.
Also, take the first opportunity in a unicom environment
to ask several other pilots how your signals sound in
relation to others in the same conversation. The single,
isolated signal report may not be terribly reliable.
Let's do that. I think I've still got your mobile number
in my phone from our last meeting at OSH . . . I think that
was 2007. Does your number still end in 6966?
Posted: Sun Mar 17, 2013 3:40 pm Post subject: radio noise |
