Square footage for painting
woxofswa
PostPosted: Mon Mar 18, 2013 8:53 am    Post subject: Square footage for painting Reply with quote
Anybody calc out a square footage or similar area dimension for painting materials/cost purposes?
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
rv10flyer(at)live.com
PostPosted: Mon Mar 18, 2013 9:33 am    Post subject: Square footage for painting Reply with quote
from Tims site
I used about 3 gallons of white, but I could have used a whole lot more
paint than I did. My goal was to paint the plane enough to hold me over for
a few years than get it redone, so 4-5 gallons may be more appropriate.
paint_dimensions.doc
 Filename:  paint_dimensions.doc
 Filesize:  24 KB
 Downloaded:  431 Time(s)
rleffler
PostPosted: Mon Mar 18, 2013 9:48 am    Post subject: Square footage for painting Reply with quote
No, but I can tell you how much Sherwin Williams Jetglo and Acryglo I used.
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress.
http://forums.matronics.com/viewtopic.php?p=396489#396489
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
carl.froehlich(at)verizon
PostPosted: Mon Mar 18, 2013 1:32 pm    Post subject: Square footage for painting Reply with quote
For high end products (PPG multicolor base/clear coat), $4000 in material is a good guess - a little less if you know what you are doing. The hangar paint booth was 12'X26'x8' tall, 2x4 frame with plastic covering (wings and tail not on the plane for paint).
I live near a PPG store so I bought paint as needed, but always made sure I had enough for whatever section I was doing.
Bottom line - if you can find someone to paint your plane for under $12K, jump at it. The RV-10 is a bear to paint. I did the RV-8A with the same base/clear coat products but the shear size of the RV-10 made for many hours of sanding and rework for me - a typical amateur painter.
Carl
Thanks in advance.
Myron Nelson
Mesa, AZ
PostPosted: Mon Mar 18, 2013 2:02 pm    Post subject: Square footage for painting Reply with quote
Granted I'm no pro, but if someone is on a budget, I painted my whole plane
for under $1.5K, that included my paint gun and materials (sand paper). I do
not have a professional looking plane by ANY means, but it does the job of
protecting it. Because I painted in my garage, in California I was limited
to only a waterbased paint. I used Stewarts system with good enough success-
http://www.stewartsystems.aero/default.aspx. A good painter, like Don
McDonald made my recoated wing looks very nice, so a good painter can get a
nice job done with this paint. Spray painting is actually a lot of fun!
I did it myself and would do it again. Worse case, a professional will take
your job and repaint with less paint and make it look really good. An
example, a local plane had a terrible paint job and after 1 week at a good
shop it came back looking great, cost $4000K since all the prep involved was
sanding for 2 coats of paint.
If I can paint the plane in a garage , with no prior experience in spray
painting, anyone can do it.
n223rv(at)wolflakeairport
PostPosted: Mon Mar 18, 2013 4:16 pm    Post subject: Square footage for painting Reply with quote
The paint adherence is only as good as the surface preparation. The hardest part of painting is the surface preparation. Once that is done, painting is fairly quick.
I painted my RV-4 and was very happy with it. Apparently Van's is too, because here it is!
http://vansaircraft.com/public/rv4.htm
But for my RV-10, I wasn't going to touch it..... especially after all that fiberglass work... I knew how big of a job the -4 was and the -10 is even bigger....
But, if painting your own plane is on your bucket list, this might be your only opportunity!! Smile
-Mike KrausRV-4 sold Sad
RV-10 flying Smile
KitFox SS7 Radial building Smile
On Mar 18, 2013, at 6:01 PM, "Pascal" <rv10flyer(at)live.com (rv10flyer(at)live.com)> wrote:
[quote]--> RV10-List message posted by: "Pascal" <rv10flyer(at)live.com (rv10flyer(at)live.com)>
Granted I'm no pro, but if someone is on a budget, I painted my whole plane for under $1.5K, that included my paint gun and materials (sand paper). I do not have a professional looking plane by ANY means, but it does the job of protecting it. Because I painted in my garage, in California I was limited to only a waterbased paint. I used Stewarts system with good enough success- http://www.stewartsystems.aero/default.aspx. A good painter, like Don McDonald made my recoated wing looks very nice, so a good painter can get a nice job done with this paint. Spray painting is actually a lot of fun!
I did it myself and would do it again. Worse case, a professional will take your job and repaint with less paint and make it look really good. An example, a local plane had a terrible paint job and after 1 week at a good shop it came back looking great, cost $4000K since all the prep involved was sanding for 2 coats of paint.
If I can paint the plane in a garage , with no prior experience in spray painting, anyone can do it.
rleffler
PostPosted: Mon Mar 18, 2013 4:36 pm    Post subject: Square footage for painting Reply with quote
I'll add to my previous email......
I spent about $3,700 on paint from a Sherwin Williams distributor.
$300 on materials like tape, paper, mek, plastic, etc.
The painter spent 99 hours and my wife and I probably put in another 30 hours or so each assisting with the masking and tape. Most the time was consumed by masking for the four colors
And the compound curves of the trim lines.
Bob
On Mar 18, 2013, at 5:31 PM, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
Carl
> Thanks in advance.
> Myron Nelson
> Mesa, AZ
Bob Leffler
N410BL - Phase I
woxofswa
PostPosted: Mon Mar 18, 2013 4:58 pm    Post subject: Re: Square footage for painting Reply with quote
Thanks for the input. What I was actually doing was querying a couple of auto shops near the airport to paint the pieces for me to final assemble. They were asking for approximate square footage since RV10 meant nothing to them, but a couple of them have done aircraft projects before.
In the end, I decided against the auto shop idea. I still might self paint for the challenge, but for the time it would take me I can easily pick up extra trips at work and be money and time ahead.
Myron Nelson
Mesa, AZ
Flew May 10 2014
dmasys
PostPosted: Tue Mar 19, 2013 6:44 am    Post subject: Square footage for painting Reply with quote
I used a high end auto shop to do the painting on my RV-12, which is much
more amenable to auto shop work with its removable wings, and all of the
components will fit in a car-sized paint booth. The shop owner was a Rans
builder and he had his employees do his airplane first. The result on my
-12 looked great at first but I discovered later they did not alodine
aluminum as agreed upon since they weren't familiar with alodine and didn't
think it necessary, some alclad areas were not sufficiently scuffed to get
good adhesion and the paint started lifting off some components like the
canopy skirts after about a year (again because they weren't accustomed to
vehicles built with metals having a coat of pure aluminum). And in trying
to make a thick automotive wet look on all those pop rivets they generally
put too much paint on the plane, and had rivet-associated runs. The cost
was over $10K. But it was very cool to be able to send the wings over
locally to get painted while I was still working on the fuselage, etc.
If I had it to do again I would use the same pro aircraft shop that painted
my RV-10, which was AOG painting in Mena, Arkansas (http://www.aogpaint.com/
). They did a great job with JetGlo on a complex curvy RV-10 design (see
http://faculty.washington.edu/dmasys/N104LDinflight.jpg ) at an amazingly
low price.
So I learned there are some 'cultural' issues when having auto paint shops
work on airplanes, even very good shops such as this one was/is. Caveat
emptor...
-Dan Masys
RV-10 N104LD
RV-12 N122LD
Time: 06:00:51 PM PST US
Subject: Re: Square footage for painting
auto
were
for
trips
Myron Nelson
Mesa, AZ
kit and
schmoboy
PostPosted: Tue Mar 19, 2013 8:19 am    Post subject: Square footage for painting Reply with quote
Just looking into this also as I'm 90% done and 90% to go. Smile
One thing I was curious about is does the builder normally do the
control surface removal and re-assembly at the paint shop? I think I
would want to just to have piece of mind that it was put back together
per plans.
-Sean #40303 (fwf)
low price.
emptor...
-Dan Masys
RV-10 N104LD
RV-12 N122LD
> From: "woxofswa" <woxof(at)aol.com>
auto
were
for
trips
> Myron Nelson
> Mesa, AZ
kit and
dmasys
PostPosted: Wed Mar 20, 2013 7:57 am    Post subject: Square footage for painting Reply with quote
I think you can negotiate what you want regarding reassembly with most paint
shops. My RV-7A was painted at Gillespie field in San Diego, and the
painter just left a hangar full of painted assemblies (rudder, elevators,
flaps, ailerons, canopy) sitting there for me to put back on the plane.
Which I remember doing on a day when the temperature was 102 degrees. Razz
The shop in Arkansas used a local A&P for disassembly and reassembly and
included that in the price, saying it was part of their normal workflow with
certificated aircraft and they didn't really want to change the process to
have a builder working on his plane in their shop areas. Which was fine
with me since it seemed like a pretty toxic environment - no dust or
pverspray but lots of fumes that everybody was breathing in. But I sure
checked everything when I picked the plane up, for which I flew the RV-7A
with a CFI friend from Nashville over to Arkansas. This gave the
opportunity for one of the coolest pictures of the -10 fresh out of the
paint shop, with its little brother:
http://faculty.washington.edu/dmasys/RV7-RV10-Mena.jpg
Funny story about that RV-10 paint job was that I took the plane in sometime
in November of 2007 and they told me there would be a ten day delay in
starting the project, since deer hunting season started the day after I
delivered the plane, and the entire shop staff would be out in the woods. Smile
-Dan
Subject: Re: Re: Square footage for painting
One thing I was curious about is does the builder normally do the control
at the paint shop? I think I would want to just to have piece of mind that
it was put back together per
plans.
-Sean #40303 (fwf)
