lamber(at)videotron.ca Guest
Posted: Fri Mar 15, 2013 1:10 pm Post subject: Ground connection |
I have a single seat wood aircraft and the battery is just being the
seat. I am running a ground wire (#6) on the left side of the cockpit
and would like to connect 2 or 3 ground wire to it near the instrument
panel. Any suggestion on how to do that without cutting it?
Ray
Posted: Sat Mar 16, 2013 10:40 am Post subject: Ground connection |
At 04:08 PM 3/15/2013, you wrote:
the seat. I am running a ground wire (#6) on the left side of the
cockpit and would like to connect 2 or 3 ground wire to it near the
instrument panel. Any suggestion on how to do that without cutting it?
Not with any grace . . . the elegant technique
calls for a single point ground on the fire wall
from whence all other grounds radiate . . . like
this (or your own incarnation of the idea).
http://aeroelectric.com/Pictures/Grounding/Forest_of_Tabs_Ground_Kit.pdf
Bob McC
Posted: Sat Mar 16, 2013 11:33 am Post subject: Ground connection |
Not elegant, not designed for aircraft use, but - - designed to accomplish tapping into a "straight through" conductor without cutting, as you've asked for.
http://tinyurl.com/amv2z6e
Bob McC
[b]> --
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sat Mar 16, 2013 2:26 pm Post subject: Ground connection |
At 02:32 PM 3/16/2013, you wrote:
| Quote: | Not elegant, not designed for aircraft use, but - - designed to accomplish tapping into a "straight through" conductor without cutting, as you've asked for.
Bob McC |
You beat me to it Bob . . . I was
just thinking about this that option
on the way home about 15 miles ago.
Another option is to simply bare some
conductors along 1" or so of the main
cable run and simply solder the necessary
'branch' wires to it after wrapping them
a few turns around the run. I don't think
this would any less elegant than the
split bolt approach . . . and it would make
less of a lump under a wrapping of tape.
Tape, wuderful stuff . . . hides lots of
sins! Some silicone guide-line tape would
be a good choice . . .
Bob . . . [quote][b]
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Sun Mar 17, 2013 5:24 am Post subject: Re: Ground connection |
If you are gonna’ splice and solder, you MUST have a good mechanical connection; otherwise vibration can easily cause separation. A solid mechanical connection is usually achieved by wrapping a couple of turns of the branch wire around the main cable. The only problem with this method is that, especially for heavy cables, you now have a branch wire that wants to exit at 90 degrees. If you need the cables parallel, which is usually the case, I have had success achieving a good mechanical connection by using copper strands stripped from flexible building wire to wrap and tie several turns around both cables after very lightly tinning both cables before the final soldering.
BTW, split bolts work great to give a bulletproof mechanical connection; although as Bob says, somewhat bulky. One thing I would caution about split bolts – If you EVER need to splice in aluminum wire; and especially when splicing aluminum to copper, make sure that you use the plated variety (not bare copper) of split bolt, along with some anti-oxidant compound. Please don’t ask me how I know.
_________________ Jerry King |
Posted: Sun Mar 17, 2013 6:04 am Post subject: Ground connection |
On 3/17/2013 9:24 AM, racerjerry wrote:
Jerry King
http://forums.matronics.com/viewtopic.php?p=396405#396405
Thank you guys,
I will try something that I found in AeroElectric_Connection_E-Book chapter 09, page 9-7, figure 9-5.
Thanks again
Ray
Posted: Sun Mar 17, 2013 12:32 pm Post subject: Ground connection |
Thank you guys,
Not sure this is applicable to your task. I
think the design goal is to make a reliable
electrical connection to a ground where
you've decided that you don't want to 'break
into' the wire.
You don't have big mechanical issues here. This
isn't a span of wire between poles and exposed to
the weather. I think I would bare a short run of
strands in the main wire, say 1" and lay one or
more strands of your new branch conductors along
side. Then harvest a couple fine strands of wire,
several inches from a piece of scrap. Use these
strands to bind the branch wires to the main wire,
then solder and wrap with silicone rubber tape
(self bonding without adhesive).
This should produce an electrically reliable
connection with more than adequate mechanical
characteristics.
Here's another case where individual strands
from the wire's lay-up are pressed into service
as an aid to fixturing the principal conductors
while the joint is being soldered.
http://tinyurl.com/c5v2xvm
