Front seat heat
EdKranz
PostPosted: Sat Mar 02, 2013 1:25 pm    Post subject: Front seat heat Reply with quote
Has anyone come up with a good way to have the front heat duct be able to heat the pilots side and copilots side differently? My wife is a freeze baby, and I hate being hot. I don't there there is a temperature range that we're both comfortable at. Dual zone climate control in our cars has saved my sanity!
I'm guessing at the simple end of things, could I just put some eyeball vents on the ducts? Has anyone built some sort of adjustable differential airflow valve to go in place of the tee fitting?
Ed Kranz
RV10
Finishing
www.edandcolleen.com
Bob Turner
PostPosted: Sat Mar 02, 2013 1:45 pm    Post subject: Re: Front seat heat Reply with quote
My short arms could never reach eyeball vents at my feet, in flight. Sounds like what you want is a butterfly valve in the middle of the T that splits the heat. Maybe driven by an electric motor?
Or duct tape covering 3/4 the opening on your side?
Bob Turner
RV-10 QB
Strasnuts
PostPosted: Sat Mar 02, 2013 1:54 pm    Post subject: Front seat heat Reply with quote
I have an aluminum door that is adjustable on my side only. Saves me, my wife has the same issue.
On Mar 2, 2013, at 13:20, Ed Kranz <ed.kranz(at)gmail.com (ed.kranz(at)gmail.com)> wrote:
[quote]Has anyone come up with a good way to have the front heat duct be able to heat the pilots side and copilots side differently? My wife is a freeze baby, and I hate being hot. I don't there there is a temperature range that we're both comfortable at. Dual zone climate control in our cars has saved my sanity!
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
flying-nut(at)cfl.rr.com
PostPosted: Sat Mar 02, 2013 2:28 pm    Post subject: Front seat heat Reply with quote
I'm working on something that may help .....
For background, my RV-10 friend said that the back seat heat blows up right behind his right shoulder while the left is cold.
I'm adapting a snap-vent from aircraft Spruce so the heat can be directed.
Here's where I'm at:
[img]cid:part1.00080509.09030107(at)cfl.rr.com[/img]
One prototype with just a round disk, one with a 'handle'.
and
[img]cid:part2.09080901.01010807(at)cfl.rr.com[/img]
The tube is 2"PVC pipe that fits inside the "T" holes. the ring is a thin section of 2" pipe glued to the end ..... and no, it doesn't go all the way around.
The tube needs to be about 2" long to fit the back seat heat vents.
I used a 3 1/4" hole saw to cut a disk out of 1/16" plastic I had laying in my scrap bin.
A 1 7/8 hole saw cuts the hole for the PVC tube. Some sanding needs to be done to fit the PVC tube.
I'm planning on using the red silicone to glue the snap-vent to the plastic disk and on the PVC tube to keep it inside the vent hole.
The rear can be adjusted by the back seaters .... but the front will have to be set on the ground.
Similarly, plastic plugs can be inserted in the "T" holes with various size holes (think baby powder cap) to regulate the amount of air.
Actually, blocking off part of the hole with metal-tape would be easier .......
Linn
Checked by AVG - www.avg.com
03/02/13
 Filesize:  86.2 KB
 Viewed:  9412 Time(s)
 Filesize:  85.83 KB
Tim Olson
PostPosted: Sat Mar 02, 2013 2:55 pm    Post subject: Front seat heat Reply with quote
Duct tape would melt into a sticky mess but a guillotine valve would work nice.
Tim
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=395443#395443
Strasnuts
PostPosted: Sat Mar 02, 2013 5:36 pm    Post subject: Front seat heat Reply with quote
That's what mine is. I put two shoulder bolts into nutplates. One to pivot
on and one to slide down a slotted arc. The aluminum piece looks like a
small pizza slice.
780 Hours
SuperSTOL 60 hours
johngoodman
PostPosted: Sun Mar 03, 2013 6:23 am    Post subject: Re: Front seat heat Reply with quote
Electric Seat heaters work great. We rarely need much heated air.
John
cjhukill(at)cox.net
PostPosted: Sun Mar 03, 2013 9:36 am    Post subject: front seat heat Reply with quote
here is what you need (scroll to last item on the page)
http://www.aviacompinternational.com/connectors.html
Chris Hukill
Strasnuts
PostPosted: Sun Mar 03, 2013 9:43 am    Post subject: front seat heat Reply with quote
Nice find Chris! I bet this would work great. I would have bought this if
it was available when I was building.
780 Hours
SuperSTOL 60 hours
Bajajim
PostPosted: Sun Mar 03, 2013 10:01 am    Post subject: front seat heat Reply with quote
I have both seat heat and seat cooling in mine. Both work Great. If you balance the rear and front heat vents you can control the temperature very easily. Its a GREAT airplane I like it better than my Mooney Bravo
Bajajim
PostPosted: Sun Mar 03, 2013 1:58 pm    Post subject: front seat heat Reply with quote
Seatcoolers.com I purchased them a few years ago. 75 each??or so.
Like I said they do work...
Sent from my Verizon Wireless BlackBerry
rv10flyer
PostPosted: Sun Mar 03, 2013 6:09 pm    Post subject: Re: Front seat heat Reply with quote
I used UL 181 aluminum foil tape rated at 260F. Simple, out of sight and works great.
Wayne G.
