hans-chr.erstad(at)c2i.ne Guest
Posted: Wed Mar 06, 2013 10:12 am Post subject: SV: SV: SV: IO-240 alternator drive coupling |
Thanks for sharing your experience and photo
I agree that "TCM should issue an apology". An idea, maybe I should try
writing them.
Hans Christian
-----Opprinnelig melding-----
Fra: owner-kis-list-server(at)matronics.com
[mailto:owner-kis-list-server(at)matronics.com] På vegne av
Keith.Miller(at)esa.int
Sendt: 5. mars 2013 09:28
Til: Hans Christian Erstad
Emne: Re: SV: SV: IO-240 alternator drive coupling
Hans ,
yours looks actually worse than mine ( see picture) but the same failure
mode, I agree this design will always wear out with age hardening and the
hot oil, Not sure why TCM switched from the old design to the new design ,
As my engine shop has never heard of a failure or problem with the old
design, maybe TCM thought they could make a few $ on the spares market ,
When I rang around the Chop shops , none had one in stock, hence i went to
the refurbish solution . But since the chop shops all know about this part
and they know the price of the TCM new parts they price the old design
accordingly. One told me he sells the old style coupling for 300 Pounds
complete or for just 50 pounds more he would throw in the Alternator .
I think TCM should issue an apology to all owners ( since the new
couplings are used on most new TCM designs) and switch back to the old
design , or price the part at what its actually costs (TCM are not buying
them at 1100 $ each )
Keith
(See attached file: DSCF5932.jpg)
| Quote: | ---------------------------------------------------------------------------
|"Hans Christian Erstad" <hans-chr.erstad(at)c2i.net>
| To: |
|<Keith.Miller(at)esa.int>
| Date: |
|04/03/2013 21:47
| Subject: |
Keith
Yes, I remember your postings from last summer. I was hoping my standard
Gill battery was not able to draw much charging current and my coupling
would last longer. That was all wrong.
I think time, heat and oil just eat the rubber away. Perhaps it will fail
regardless of generator load. I enclose a photo.
I have a friend that has som extra O-200 parts - a generator with the old
style coupling. If I am lucky I can use parts from this and buy new the
components that SB95-3B require to be replaced every 500h. ($42 (at)Spruce)
Thanks to this forum I had a wealth of information about the generator
problem - even before I had the problem
Thanks a lot Keith and others.
Hans Christian
Fra: Keith.Miller(at)esa.int [mailto:Keith.Miller(at)esa.int]
Sendt: 4. mars 2013 10:07
Til: kis-list(at)matronics.com
Kopi: hans-chr.erstad(at)c2i.net
Emne: Re: SV: IO-240 alternator drive coupling
Hans
I posted quite a bit on this point back in July 2012 , when mine failed at
about 400 hours . I didn't follow the post up with my solution (Sorry) ,
but in the end I went for an overhauled part through Aircraft quality
accessories in the USA ( see OC posting for the Link ) they were very
fast at sending the unit to me ( Too fast in my opinion as they used an
expensive courier service ) , Part itself is expensive for what it
actually is, but they returned the $500 deposit as soon as they received my
old core.
I did all the research (as per Johns note) about replacing the unit with the
old mechanical solution , and I agree with John. The old mechanical design
should not fail due its simplistic design, whereas the new one piece
coupling is always going to fail eventually as the rubber gets old , and
once it starts to slip it will rapidly wear out- but good news is is that
it can not damage the engine , just a bit of fine rubber residue in the
oil .
When I spoke with Aircraft quality accessories, they said it was a regular
replacement part ( 2 to 3 per week ) ,and they did quite good business out
of this part. ,they also told me that they get more orders in the hot
summer months , when owners are switching on the Airco and loading the
alternator to a max before they get into the air, and that it is unlikely to
survive for long periods when there is a max current draw from the 60amp
TCM alternator.
In my case I put my failure down to my decision to switch to a Lithium
Phosphate main battery without first redesigning the charging circuit ,
since these batteries demands huge currents from the alternator just after
start up.
Replacement process is quite easy , took me about 4 hours in total (
requires the removal of one magneto to get to one of the bolts - no way
around that )
Good luck with your decision and replacement,
Keith
| To: |
|<kis-list(at)matronics.com>
| Date: |
|03/03/2013 21:00
| Subject: |
| Sent by: |
Thanks OC
Yes, it sound like I have identified all options - and there are quite a
few.
Looking at the failed on-piece coupling, I think it is not designed to last,
only to make money
I think the best option is to find used parts for the multi piece coupling,
but buy new the bushing and retainer that according to SB95-3B is to be
This Service Bulletin have been useful providing information on part
numbers, torque etc. However it seems like the one-piece coupling never
reaches 500h, so the SB is to no help there, apart from stating "The one
piece coupling may be substituted for the coupling assembly shown in Figure
1." Maybe they issued the SB to infrom about this substitution when they
realized that the one-piece is flawed.
The SB calls for the couling to be tested for 100 inch punds of torque.
Probably all 500h couplings will fail this test? and will require
replacement with the substitute. Anyone know about a 500h coupling that have
passed the test?
Hans Christian
Fra: owner-kis-list-server(at)matronics.com [
mailto:owner-kis-list-server(at)matronics.com] På vegne av Owen Baker
Sendt: 3. mars 2013 14:08
Til: ERSTAD HANS-CHRISTIAN; KIS-LIST MATRONICS
Emne: IO-240 alternator drive coupling
3/3/2013
Hello Hans Christian, I am sorry to read of your alternator drive coupling
problem. The attached copy of TCM SB95-3B provides some relevant
information.
I think that you have a very good grasp of the four solutions to the
problem.
They are: a) purchase and install the multi piece coupling, b) convert to a
front drive alternator, c) purchase and install a one piece coupling from
CMI (Continental Motors Inc. -- new name), purchase and install an
aftermarket rebuilt one piece coupling.
Regarding each solution:
a) The multi piece coupling was replaced by the one piece coupling as the
one piece coupling was considered superior. That point may be debated.
b) The IO-240 B3B engine in the Diamond DA 20-C1 airplane uses the front
mounted alternator. One could maybe source the parts needed from a Diamond
aircraft dealer. I don’t know if that model airplane was ever introduced
outside of the USA and Canada. In addition to obtaining and installing the
front of the engine parts needed one would also have to seal off the left
open alternator drive access hole in the rear of the engine.
c) Purchase a one piece coupling from CMI. The most expensive initial course
of action.
d) The aftermarket one piece coupling can be purchased from these people:
http://www.qualityaircraftaccessories.com/Default.aspx?A=ProductSearch&ID=/s
earch-results&SE=True&q=635796
for an initial cost of $1,095.00 US. They are supposed to refund $500 US of
that when they receive your returned old one piece core.
Please let me know if I can be of further help.
‘OC’
'O C' Baker says "The best investment you can make is the effort to gather
and understand information."
Sent: Mar 2, 2013 12:55 PM
To: kis-list(at)matronics.com
Subject: IO-240 alternator drive coupling
I have read several
postings about early failure of the IO-240 alternator drive coupling (P/N
635796).
The coupling failed
now at 337 hours in my IO-240 powered KIS. From other postings, it seems
like this part never reaches 500 h, and cost a fortune to buy new (more than
$2000), but may be overhauled for $600.
The failure rates
indicate to mee that this part (too) is a bad design.
Apparently it is
possible to replace the one piece coupling, with one that contain of several
parts (531325, 530407, 632050, 653982, 653983) and have been used on other
Continental (e.g. O-200).
What have the
experience been for you that have IO-240 ?
Any suggestion for
best place to get the one-piece overhauled? or suggestions for where to buy
the serveal-piece alternative?
Hans Christian
Erstad
This message and any attachments are intended for the use of the addressee
or addressees only. The unauthorised disclosure, use, dissemination or
copying (either in whole or in part) of its content is not permitted. If you
received this message in error, please notify the sender and delete it from
your system. Emails can be altered and their integrity cannot be guaranteed
by the sender.
Please consider the environment before printing this email.
[attachment "IMG_1904.JPG" deleted by Keith Miller/estec/ESA]
by the sender.
