larkrv10(at)gmail.com Guest
Posted: Mon Feb 25, 2013 3:58 pm Post subject: Fuel Lines |
Hey all
I started to fabricate the fuel lines in the tunnel etc today and where I attached the line to the firewall, I recently bought a AN832 steel bulkhead fitting (straight) instead of an AN837 bulkhead fitting (45 degree). For those that have installed the fuel line to the engine, can I get away with the straight fitting or should I return it for the 45 degree fitting? I intend to mount the fuel flow transducer under the engine (if that helps).
Thx, Rick
#40956
Southampton, Ont
dave.saylor.aircrafters(a Guest
Posted: Mon Feb 25, 2013 7:22 pm Post subject: Fuel Lines |
You should be OK but it might mean getting something other than the
hose provided by Vans (Bonaco could make one). You can get a custom
hose with a 45* or 90* fitting built in to the end. You did good by
changing the provided aluminum fitting to steel.
Dave Saylor
831-750-0284 CL
On Mon, Feb 25, 2013 at 3:56 PM, Rick Lark <larkrv10(at)gmail.com> wrote:
| Quote: | Hey all
Thx, Rick
#40956
Southampton, Ont
schmoboy
Posted: Mon Feb 25, 2013 7:47 pm Post subject: Fuel Lines |
The reason for the 45 degree fitting or 45 degree hose end is because
the engine mount and nose gear isolators are right to the left of and in
front of that fitting. The angle allows the hose to loop out and around
the engine mount and isolators before heading on its way to the engine
driven fuel pump.
-Sean #40303 (adding controls and fuel lines to engine)
On 2/25/13 9:20 PM, Dave Saylor wrote:
Dave Saylor
831-750-0284 CL
> Hey all
> Thx, Rick
> #40956
> Southampton, Ont
aircraftspecialty(at)gmai Guest
Posted: Mon Feb 25, 2013 10:37 pm Post subject: Fuel Lines |
Also, take a look at www.kitplanehoses.com.
We have online pricing so you can "build" and order you hose directly from our website. Our hoses are all conductive Teflon with stainless ends. And, they are a true 37degree aviation flare.
If you have any questions, please go to
Www.kitplanehoses.com or email us at
Steve(at)aircraftspecialty.com
Have a great evening
On Feb 25, 2013, at 21:20, Dave Saylor <dave.saylor.aircrafters(at)gmail.com> wrote:
Dave Saylor
831-750-0284 CL
> Hey all
> Thx, Rick
> #40956
> Southampton, Ont
Posted: Tue Feb 26, 2013 4:04 am Post subject: Fuel Lines |
Sean/Dave, thx for the info. I'm heading to Aircraft Spruce today and will take the straight fitting with me and see if they will exchange it. For the record, I did not buy Vans engine hoses, so the custom hose option is still open.
Regards, Rick
On Mon, Feb 25, 2013 at 10:46 PM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote]--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
The reason for the 45 degree fitting or 45 degree hose end is because the engine mount and nose gear isolators are right to the left of and in front of that fitting. The angle allows the hose to loop out and around the engine mount and isolators before heading on its way to the engine driven fuel pump.
| Quote: | --> RV10-List message posted by: Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)>
Dave Saylor
[url=tel:831-750-0284]831-750-0284[/url] CL
On Mon, Feb 25, 2013 at 3:56 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
| Quote: | Hey all
Thx, Rick
#40956
Southampton, Ont
http://forums.matronics.com
le, List Admin.
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Tue Feb 26, 2013 7:22 pm Post subject: Re: Fuel Lines |
Rick,
Here is how it looks coming out of the firewall to the pump
105.88 KB |
6014 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Posted: Wed Feb 27, 2013 5:54 pm Post subject: Fuel Lines |
Aha, thx. I got to Aircraft Spruce (at) CYFD yesterday and switched the fitting I had for the 45 degree one. Glad I did by the looks of your photo.
So the fuel route is fuel pump, transducer, distribution spyder, cylinders? Not sure thats correct?
Rick
On Tue, Feb 26, 2013 at 10:22 PM, bill.peyton <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)> wrote:
[quote]--> RV10-List message posted by: "bill.peyton" <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
Rick,
Bill
WA0SYV
http://forums.matronics.com/viewtopic.php?p=395147#395147
http://forums.matronics.com//files/img_2522_859.jpg
le, List Admin.
bill.peyton
Posted: Wed Feb 27, 2013 6:01 pm Post subject: Re: Fuel Lines |
Rick,
The routing is
engine driven fuel pump--fuel servo--FF transducer--spider--cylinders
WA0SYV
Kelly McMullen
Posted: Wed Feb 27, 2013 6:14 pm Post subject: Fuel Lines |
firewall, fuel pump, servo, distributor, injectors. You can insert the transducer either between the pump and servo, or between the servo and the distributor. EI, who makes the transducer has it between the pump and the servo on their STC for certified planes, but several folks here have had success between servo and distributor, which is normal location for Continental fuel injection with fuel return line, that Bendix FI does not have.
On Wed, Feb 27, 2013 at 6:49 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote] Aha, thx. I got to Aircraft Spruce (at) CYFD yesterday and switched the fitting I had for the 45 degree one. Glad I did by the looks of your photo.
Rick
A&P/IA, EAA Tech Counselor
KCHD |
