Kelly McMullen
Posted: Mon Feb 18, 2013 12:22 pm Post subject: Battery choices |
Thank you for mentioning that. It looks like the Odyssey PC925 will also fit when turned on its side. I think some builders have used it that way. Anyone have arguments for one or the other? The PC925 seems to be about the same wt, a few amp hrs more than the BC-100-1 and the RG 25XL Concorde. I'd like to have about same wt and amp hours (or more) than the Concorde which I was leaning towards. I don't feel the PC680 has enough amp hours capacity for my preferences, while it may be fine for other elect system designs.
On Mon, Feb 18, 2013 at 7:39 AM, David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)> wrote:
[quote] I use the BC100-1 from B&C Specialty products. Stand it on its side in the standard Van's try with no modification.Plenty of power.
David Leikam
RV10
A&P/IA, EAA Tech Counselor
KCHD |
aerosport1
Posted: Mon Feb 18, 2013 1:38 pm Post subject: Battery choices |
I love my PC925. Works great on its side and still cranking.
Geoff Combs
Aerosport Modeling and Design
8090 howe industrial pkwy
canal winchester, ohio 43110
614.834.5227p
614.834.5230f
www.aerosportmodeling.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Monday, February 18, 2013 3:22 PM
Subject: Battery choices
| Quote: | I use the BC100-1 from B&C Specialty products. Stand it on its side in the standard Van's try with no modification. Plenty of power.
David Leikam
RV10
555.19 KB |
1334 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
