Beegee5872
Posted: Fri Jan 25, 2013 12:14 pm Post subject: L-29 air-pump for pneumatic system |
Does anyone have plans or directions on how to install an air-pump into the L-29 pneumatic stem?
I’m looking to use it to supplement the nitrogen and not to replace it.
Beegee5872(at)juno.com
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
_________________ Bill |
delfin29(at)me.com Guest
Posted: Fri Jan 25, 2013 1:15 pm Post subject: L-29 air-pump for pneumatic system |
I have one on my L-29.
Unfortunatly, I will not have access to my L-29 or my docs before one month more or less.
Working perfectly since 10 years.
Place in front right size where was the original IFF.
Jean de ROUBIN
B. P. 2775
NOUAKCHOTT
MAURITANIE
+222 44 55 30 24
+33 6 20 26 76 90
delfin29(at)me.com
schwartzcompany(at)att.ne Guest
Posted: Fri Jan 25, 2013 1:21 pm Post subject: L-29 air-pump for pneumatic system |
How did you avoid moisture in the system
To: <l29-list(at)matronics.com>
Sent: Friday, January 25, 2013 3:14 PM
Subject: Re: L-29 air-pump for pneumatic system
month more or less.
Jean de ROUBIN
B. P. 2775
NOUAKCHOTT
MAURITANIE
+222 44 55 30 24
+33 6 20 26 76 90
delfin29(at)me.com
> Bill
> http://forums.matronics.com/viewtopic.php?p=393043#393043
Posted: Fri Jan 25, 2013 1:24 pm Post subject: L-29 air-pump for pneumatic system |
Filter and purge after each flight.
Le 25 janv. 2013 à 21:21, ROBERT SCHWARTZ <schwartzcompany(at)att.net> a écrit :
Beegee5872
Posted: Wed Jan 30, 2013 11:34 am Post subject: Re: L-29 air-pump for pneumatic system |
Hi Jean,
When you get a chance I would really appreciate if you can how the air-pump was installed, any special parts, what connects to what, where did you put the slump & drain, what type of fittings you used, how did run the electric (DC), where did you put the switch, do you only operate the pump on the ground, what type/brand of air-pump, how did you install the filter, what type of filter, you know basically all the info I need to put on another L-29; which is a great flying machine....
________________________________________
Jean de ROUBIN
B. P. 2775
NOUAKCHOTT
MAURITANIE
+222 44 55 30 24
+33 6 20 26 76 90
delfin29(at)me.com
Posted: Wed Jan 30, 2013 11:42 am Post subject: L-29 air-pump for pneumatic system |
Hi, Bill
As soon I will fly my L-29 (witch is in Barcelona by now), I will give you all details. May be in one month.
There is a switch on the main board (right and pilot). It works when pressure is less than 20 bars, and stop when it reach 50 bars.
I drain it after each flight.
It is ON in flight, except for aerobatics.
Best
Jean de Roubin
Le 30 janv. 2013 à 19:34, Beegee5872 <Beegee5872(at)juno.com> a écrit :
Hi Jean,
Jean de ROUBIN
B. P. 2775
NOUAKCHOTT
MAURITANIE
+222 44 55 30 24
+33 6 20 26 76 90
delfin29(at)me.com
Bill
http://forums.matronics.com/viewtopic.php?p=393298#393298
Beegee5872
Posted: Thu Jan 31, 2013 12:47 pm Post subject: Re: L-29 air-pump for pneumatic system |
Thank you Jean, I look forward to hear all about it; other than the finite limits of the pneumatic brakes the L-29 is a great flying machine..., adding an air will go far to increase the flight missions. Jean, you still use the nitrogen system, it’s intact and the air pump acts a supplement air source...
Many thanks,
Bill
czech6(at)mesanetworks.ne Guest
Posted: Thu Jan 31, 2013 3:07 pm Post subject: L-29 air-pump for pneumatic system |
I converted all oxygen and nitro bottles that come stock into nitrogen. In the cockpit I have a shut-off valve that opens the old oxygen bottles to top off the brake system. Carry my own reserve. No leaks. If the pressure goes down just open the valve, pressurize the system to approx. 50-60ATM then close it until the next time.
Bill
On Jan 31, 2013, at 2:47 PM, "Beegee5872" <Beegee5872(at)juno.com> wrote:
Many thanks,
Bill
Bill
http://forums.matronics.com/viewtopic.php?p=393373#393373
