Torque Tube Clamp Standard Mod 11906
Patrick Tunney
PostPosted: Sat Jan 19, 2013 9:15 am    Post subject: Torque Tube Clamp Standard Mod 11906 Reply with quote
All i have had a small batch of clamps machined to a new design. The standard mod will be updated shortly. The attached document details the changes and shows the new clamps prior to machining the bores.
The standard mod form is available from the LAA website.
Please contact me for further information if you are interested.
As already mentioned on this forum, Bob H takes all the credit for the clamp idea, i have just modified slightly.
Pat Tunney
Kit 554
www.europaxs.com
TTC New and Existing.pdf
 Filename:  TTC New and Existing.pdf
 Filesize:  574.67 KB
 Downloaded:  533 Time(s)
Alan Carter
PostPosted: Tue Jan 22, 2013 2:48 pm    Post subject: Re: Torque Tube Clamp Standard Mod 11906 Reply with quote
Hello Pat.
I posted some time ago a topic on the Europa Torque Tube and a lot of ingenious idea,s where posted, however many where not LAA approved.
See yours are approved, and i see the new radius comparing the older design, i like the way you have got rid of those awful split pins, on the dowels.
So have decided to fit them to my aircraft. Have sent you an e-mail for further information. But please put a set aside for me i will need them soon by March.
Many Thanks
Alan
churchy
PostPosted: Wed Jan 23, 2013 4:41 am    Post subject: Torque Tube Clamp Standard Mod 11906 Reply with quote
Hi Pat
Can you please reserve a pair for me.
Richard Churchill-Coleman
Pat Tunney
Kit 554
www.europaxs.com
http://forums.matronics.com/viewtopic.php?p=392643#392643
http://forums.matronics.com//files/ttc_new_and_existing_151.pdf
