Cockpit Paint Question
tgesele(at)optonline.net
PostPosted: Thu Jun 08, 2006 4:16 am    Post subject: Cockpit Paint Question Reply with quote
For those that have installed a FlightLine interior, what areas of the
cockpit are left uncovered and need to be painted?
Tom Gesele #40473 - Fuselage
Tim(at)MyRV10.com
PostPosted: Thu Jun 08, 2006 10:43 am    Post subject: Cockpit Paint Question Reply with quote
Around the doors and fiberglass top. The Glareshield and
panel. A little bit of the sidewalls right under the panel,
and above those side panels on the very aft edges of the panel.
You may also want to paint around the metal box tube that
the rear seatbacks rest against, but she makes a cover that
will cover most of it. On the aft area where the rear door
latch pins come thru, you'll want to paint too, and around your
baggage door openings. If I were you, I'd just look at a
few of the photos and paint everywhere that you don't
definitely see carpet or panels, that way any of the exposed
edges look nice.
