Low idle RPM recommendation on Rotax 912 UL?
triumphrider
PostPosted: Wed Dec 26, 2012 1:24 pm    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
How low should the low idle speed be adjusted for on the Rotax 912 UL?
I had someone help with it and he said 1400 rpm and if I pull the throttle that low, the engine shutters. I usually taxi at around 1800 RPMs. With the reduction gear of the Rotax, perhaps 1400 rpm idle is too low? Previously, pulling the throttle back for low idle was at 2000 rpm. It was readjusted for they lower speed.
Engine seems dialed in at cruise and acceleration, but a little rough at low idle, as if the prop is not balanced. I did a few small carbon fiber prop ding repairs and was careful not to overweight one side. Perhaps, I did it inadvertently? It's a Prince P-Tip. Used to purr like a kitten. As the Chinese say, if it's not broken don't fix it? It was adjusted at the conditional inspection. Is perfection too much to expect from a 850 hr. engine? Am I asking too much i was told to do a Bing carb adjust every 50 hours. I have about 20 hours in the aircraft, but you get to know your bird pretty quickly.
briana(at)xtra.co.nz
PostPosted: Wed Dec 26, 2012 2:04 pm    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
I think 1400rpm is definitely too low, and at that speed you should expect to get a deal of gearbox chatter. I'm happy with the engine idling at about 1700. Idle should be smooth at that speed if the carbs are properly synchronised.
Brian
On 27/12/2012, at 10:24 AM, "triumphrider" <investmentsalesconsultant(at)gmail.com> wrote:
Engine seems dialed in at cruise and acceleration, but a little rough at low idle, as if the prop is not balanced. I did a few small carbon fiber prop ding repairs and was careful not to overweight one side. Perhaps, I did it inadvertently? It's a Prince P-Tip. Used to purr like a kitten. As the Chinese say, it it's not broken don't fix it? It was adjusted at the conditional inspection. Is protection too much to expect from a 850 hr. engine? Am I asking too much?
http://forums.matronics.com/viewtopic.php?p=390994#390994
pilot623(at)gmail.com
PostPosted: Wed Dec 26, 2012 2:14 pm    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
I agree that 1400 is too low. I usually idle at 2000 to avoid the gearbox
chatter issue.
Jim
esalehto(at)yahoo.com
PostPosted: Wed Dec 26, 2012 6:47 pm    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
Hi
My idle speed is set as well to 2000 rpm.
Esa
To: pulsar-list(at)matronics.com
Sent: Wednesday, December 26, 2012 2:13 PM
Subject: RE: Pulsar-List: Low idle RPM recommendation on Rotax 912 UL?
--> Pulsar-List message posted by: "pilot623" <pilot623(at)gmail.com (pilot623(at)gmail.com)>
chatter issue.
Jim
bernard.wilder2(at)gmail.
PostPosted: Thu Dec 27, 2012 7:02 am    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
Lockwood course instructions was for an idle of 1,400 to 1,600 BUT they add that you shouldn't run your engine that slow,,, because, as you have found ouit, at that slow an idle the engine doesn't run smoothly.
My engine won't stall at 1,500. But that said, I idle at no less than 2,000.
I also have a Prince P Tip.   Love it ! ! !
Bernie Wilder
On Wed, Dec 26, 2012 at 4:24 PM, triumphrider <investmentsalesconsultant(at)gmail.com (investmentsalesconsultant(at)gmail.com)> wrote:
[quote] --> Pulsar-List message posted by: "triumphrider" <investmentsalesconsultant(at)gmail.com (investmentsalesconsultant(at)gmail.com)>
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
target="_blank">http://www.matronics.com/Navigator?Pulsar-List
MyronTruex(at)comcast.net
PostPosted: Thu Dec 27, 2012 8:24 am    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
Carbs balanced and Idle at 1900-2000. However, I adjusted my throttle so I could pull it back to 1500 rpm. I could get a bit shorter roll out on landing. You will be amazed what carb balancing can do.
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Bernard Wilder
Sent: Thursday, December 27, 2012 7:01 AM
Subject: Re: Low idle RPM recommendation on Rotax 912 UL?
Bernie Wilder
le, List Admin.
ccoulter(at)wavecable.com
PostPosted: Fri Dec 28, 2012 12:14 pm    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
About 1800 should be OK
Clarke
On Wed, 26 Dec 2012 13:24:55 -0800
Rotax 912 UL?
asking too much?
Admin.
Un/Subscription,
Forums!
PostPosted: Sat Dec 29, 2012 9:26 am    Post subject: Low idle RPM recommendation on Rotax 912 UL? Reply with quote
Idling at that rpm is not great for the gear box but being able to pull the
engine back to that rpm is helpful on landings if you need to shorten the
rollout etc.
