Bob H
Posted: Mon Dec 17, 2012 7:40 am Post subject: Pulsar-List Digest: 9 Msgs - 12/16/12 |
If you are seeing effect on sealing tape, you have the beginnings of
leakage, either from an old hose or from end plate seal. I change my hoses
every 3-4 yrs as cheap insurance against deterioration.
If that doesn't cure problem, then I'd pull wing away from fuselage and
examine the end plate and associated fuel sender for seepage, possibly from
end plate screws or sender screws. If plate seal is deteriorating and
weeping at glass to plate joint, it needs to be removed and cleaned and
resealed with polysulphide.
Bob H
[quote] From: Pulsar-List Digest Server <pulsar-list(at)matronics.com>
Reply-To: <pulsar-list(at)matronics.com>
Date: Sun, 16 Dec 2012 23:58:25 -0800
To: Pulsar-List Digest List <pulsar-list-digest(at)matronics.com>
Subject: Pulsar-List Digest: 9 Msgs - 12/16/12
Today's complete Pulsar-List Digest can also be found in either of the
of the Pulsar-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2
012-12-16&Archive=Pulsar
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter
Pulsar-List Digest Archive
Total Messages Posted Sun 12/16/12: 9
Today's Message Index:
1. 12:54 PM - Strong Smelling Cockpit Remedy? (triumphrider)
2. 02:22 PM - Re: Strong Smelling Cockpit Remedy? (Brian Anderson)
3. 05:06 PM - Re: Strong Smelling Cockpit Remedy? (Esa Lehto)
4. 05:28 PM - Re: Strong Smelling Cockpit Remedy?
(pulsar331(at)sbcglobal.net)
5. 05:55 PM - Re: Strong Smelling Cockpit Remedy? (Keith Palmer)
6. 06:18 PM - Re: Strong Smelling Cockpit Remedy? (Brian Anderson)
7. 06:41 PM - Re: Strong Smelling Cockpit Remedy? (Keith Palmer)
8. 06:44 PM - Re: Strong Smelling Cockpit Remedy? (Brian Anderson)
9. 10:14 PM - Re: Strong Smelling Cockpit Remedy? (Esa Lehto)
________________________________ Message 1
_____________________________________
Time: 12:54:55 PM PST US
Subject: Strong Smelling Cockpit Remedy?
From: "triumphrider" <investmentsalesconsultant(at)gmail.com>
I have a Pulsar XP (860 TT on 912UL 80 HP) and the cockpit has a distinct
mechanical/
fuel smell. Nothing is leaking at the fuel line connectors to the fuel
tank selection switch. However, I do have a wee bit of very light moisture
that
has become evident at the joint of the left wing to the fuselage-at the joint
I have 1.5 Inch 3M tape I've used to close the gap as gap tape and it's
getting
a little tacky on the underside. Can't tell if it's from the fuel tank check
valve or at the joint of the wing. But, no fuel drips on the hanger floor
( I have a Carbon Monoxide alarm-so, the smell is not of exhaust or fumes. It
just smells like the cotton fabric sound covering on the walls has taken a lot
of smell over the past 14 years. Incidentally, I have not taken the wings off,
nor did the previous owner. But, I think it's plausible that it's a fuel line
connector.
Any thoughts on this? Had a similar situation. Is a Glades Fresh Scent plug-in
the answer? (If It was my wife's plane it would smell like lavender when you
pushed open the canopy! Ha!)
http://forums.matronics.com/viewtopic.php?p=390552#390552
________________________________ Message 2
Time: 02:22:17 PM PST US
Subject: Re: Strong Smelling Cockpit Remedy?
A number of us have had fuel smells in the cockpit in the past, due primarily
to
inexplicable percolation of stuff through rubber fuel hoses in the cockpit.
This issue was discussed at length a few years ago both on the web group at at
the gathering in Kansas.
If this is the problem that you have then a solution is to change the hoses
out
for teflon hoses. A number of us have done that successfully. Some years back
I did a little power point presentation on the issue for the Kansas gathering.
Happy to send you a copy if you would like.
Brian
On 17/12/2012, at 9:54 AM, triumphrider <investmentsalesconsultant(at)gmail.com>
> mechanical/
that has become evident at the joint of the left wing to the fuselage-at the
joint
getting a little tacky on the underside. Can't tell if it's from the fuel tank
check valve or at the joint of the wing. But, no fuel drips on the hanger
floor
It just smells like the cotton fabric sound covering on the walls has taken a
lot of smell over the past 14 years. Incidentally, I have not taken the wings
off, nor did the previous owner. But, I think it's plausible that it's a fuel
line connector.
> plug-in
________________________________ Message 3
Time: 05:06:18 PM PST US
Hi Brian,=0A=0APlease share your presentation with all of us by posting it
to Pulsar Yahoo group.=0A=0AEsa,=0APulsar XP=0ARotax 912 UL=0A=0A=0A=0A____
____________________________=0A From: Brian Anderson <briana(at)xtra.co.nz>=0A
Subject: Re: Strong Smelling Cockpit Remedy?=0A =0A--> Pulsar-
List message posted by: Brian Anderson <briana(at)xtra.co.nz>=0A=0AA number of
us have had fuel smells in the cockpit in the past, due primarily to inexp
licable percolation of stuff through rubber fuel hoses in the cockpit. This
the gathering in Kansas.=0A=0AIf this is the problem that you have then a s
olution is to change the hoses out for teflon hoses. A number of us have do
ne that successfully. Some years back I did a little power point presentati
on on the issue for the Kansas gathering. Happy to send you a copy if you w
ould like.=0A=0ABrian=0A=0A=0AOn 17/12/2012, at 9:54 AM, triumphrider <inve
stmentsalesconsultant(at)gmail.com> wrote:=0A=0A> --> Pulsar-List message post
ed by: "triumphrider" <investmentsalesconsultant(at)gmail.com>=0A> =0A> I have
a Pulsar XP- (860 TT on 912UL 80 HP) and the cockpit has a distinct mech
anical/ fuel smell. Nothing is leaking at the fuel line connectors to the f
uel tank selection switch. However, I do have a wee bit of very light moist
ure that has become evident at the joint of the left wing to the fuselage-a
t the joint I have 1.5 Inch- 3M tape I've used to close the gap as gap ta
pe and it's getting a little tacky on the underside. Can't tell if it's fro
m the fuel tank check valve or at the joint of the wing. But, no fuel drips
on the hanger floor ( I have a Carbon Monoxide alarm-so, the smell is not
of exhaust or fumes. It just smells like the cotton fabric sound covering o
n the walls has taken a lot of smell over the past 14 years. Incidentally,
I have not taken the wings off, nor did the previous owner. But, I think it
's plausible that it's a fuel line connector.=0A> =0A> Any thoughts on this
? Had a similar situation. Is a Glades Fresh Scent plug-in the answer?- (
If It was my wife's plane it would smell like lavender when you pushed open
the canopy! Ha!)=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A>
=0A> http://forums.matronics.com/viewtopic.php?p=390552#390552=0A> =0A>
________________________________ Message 4
Time: 05:28:14 PM PST US
If you have the original resistance fuel Level sending units, don't forget t
o check the electrical connection terminal packing seal. That fiber gasket/
seal eventually dries out and leaks just enough to get wet and cause a smell
On Dec 16, 2012, at 8:05 PM, Esa Lehto <esalehto(at)yahoo.com> wrote:
> Hi Brian,
> Please share your presentation with all of us by posting it to Pulsar Yaho
o group.
> Esa,
> Pulsar XP
> Rotax 912 UL
> To: pulsar-list(at)matronics.com
> Sent: Sunday, December 16, 2012 2:21 PM
ily to inexplicable percolation of stuff through rubber fuel hoses in the co
ckpit. This issue was discussed at length a few years ago both on the web gr
oup at at the gathering in Kansas.
s out for teflon hoses. A number of us have done that successfully. Some yea
rs back I did a little power point presentation on the issue for the Kansas g
athering. Happy to send you a copy if you would like.
> Brian
om> wrote:
tant(at)gmail.com>
ct mechanical/ fuel smell. Nothing is leaking at the fuel line connectors to
the fuel tank selection switch. However, I do have a wee bit of very light m
oisture that has become evident at the joint of the left wing to the fuselag
e-at the joint I have 1.5 Inch 3M tape I've used to close the gap as gap ta
pe and it's getting a little tacky on the underside. Can't tell if it's from
the fuel tank check valve or at the joint of the wing. But, no fuel drips o
n the hanger floor ( I have a Carbon Monoxide alarm-so, the smell is not of e
xhaust or fumes. It just smells like the cotton fabric sound covering on the
walls has taken a lot of smell over the past 14 years. Incidentally, I hav
e not taken the wings off, nor did the previous owner. But, I think it's pla
lug-in the answer? (If It was my wife's plane it would smell like lavender w
hen you pushed open the canopy! Ha!)
>> www.homebuilthelp com/Navigator?Pulsar-List" target=
"_blank">http://www.matronics.com/Navig - MATRONICS WEB FORUMS -
________________________________ Message 5
Time: 05:55:16 PM PST US
After 14 years I would go along with Brian's theory of deteriating fuel
hoses.
K'd
| - The Matronics Pulsar-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
triumphrider
Posted: Wed Dec 26, 2012 1:13 pm Post subject: Re: fuel smell post/replies |
Thanks for sharing your knowledge and thoughts. As a non-builder, what size/ length of SS Fuel Lines do I need to order for the left and right? It's a Rotax 912 UL. Available at Aircraft Spruce?
briana(at)xtra.co.nz Guest
Posted: Wed Dec 26, 2012 2:11 pm Post subject: Pulsar-List Digest: 9 Msgs - 12/16/12 |
See my .ppt posting to the Pulsar Aviators group on Yahoo. Fuel Smell.PPT This gives some part numbers but the length and end fittings will be a custom fit, depending on how the builder did the installation.
The teflon fuel lines used are from Earls, but there is an equivalent Aeroquip line that Aircraft Spruce can supply.
Brian
On 27/12/2012, at 10:13 AM, "triumphrider" <investmentsalesconsultant(at)gmail.com (investmentsalesconsultant(at)gmail.com)> wrote:
[quote]--> Pulsar-List message posted by: "triumphrider" <investmentsalesconsultant(at)gmail.com (investmentsalesconsultant(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=390993#390993
-- Please Support Your Lists This (And Get * HomebuiltHELP -Matt Dralle, List - The Pulsar-List --> &n========================
