SV: Moving the tri-gear - CORRECTION
sidsel.svein(at)oslo.onli
PostPosted: Sat Dec 08, 2012 9:26 am    Post subject: SV: Moving the tri-gear - CORRECTION Reply with quote
Ref. message just posted. I forgot to state the length of the steel pipe
pieces welded to the fork arms (30 mm) - please see attached corrected
details.
Svein
LN-SKJ
Nose_wheel_fork_details.pdf
 Filename:  Nose_wheel_fork_details.pdf
 Filesize:  40.56 KB
 Downloaded:  323 Time(s)
handfordp(at)aol.com
PostPosted: Thu Dec 13, 2012 1:49 am    Post subject: SV: Moving the tri-gear - CORRECTION Reply with quote
Thank you all for the suggestions, particularly Sidsel & Svein for the detailed plans
Best regards
Peter Handford
07936 374 452 (mobile)
On 8 Dec 2012, at 17:25, "Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no> wrote:
SKJ
