		vincefrazier(at)gmail.com Guest
				 Posted: Sun Dec 09, 2012 7:47 am    Post subject: fuel pump vent clearance |
				I know of 2 other techniques to eliminate the fuel pump vent clearance problem:
 !)  From memory..... according to Tom Martin, you may be able to disassemble the fuel pump and re-clock the vent port to a different spot.
 2) From www.vincesrocket.com     Rather than disassemble the pump so the vent port would clear the firewall, I  did the following: the vent was plugged with a pipe plug.  I had to trim  the bottom of the pipe plug to clear the hose barb.   I tapped a hole  in the side of the overflow vent and installed a hose barb for the overflow  line.  Be sure to put a piece of foam inside the vent port while drilling  and tapping to keep the chips out of the pump.  And clean out all of the  foam and chips before the final assembly... duh.  I used JB Weld to  seal/glue the hose barb in place since there is no way to safety it and my  tapped hole was just a little loose.  Not shown in the picture was the  final grinding off of the pipe plug so that no excess metal was left sticking  out.   Here's a photo:  http://www.vincesrocket.com/2004-03-30/fuel%20pump%20vent%20mod.jpg
 Vince Frazier
 Flyboy Accessories
 www.flyboyaccessories.com
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		viperpilot
  Joined: 28 Aug 2012 Posts: 11 Location: Peachtree City, GA
				 Posted: Sun Dec 09, 2012 8:21 am    Post subject: Re: fuel pump vent clearance |
				Thanks, Vince!  I'll put those two tricks in my quiver.  Now, I'm wondering if I could just tap the hose plug for a barb after drilling a small hole into the pump end of the plug...  That may give me enough clearance and I would have the chips and shavings on the outside the whole while.
 I appreciate your posts and your website. They have been great sources of information over the past several months!
 Randy Sage
		smokyray(at)rocketmail.co Guest
				 Posted: Sun Dec 09, 2012 8:55 am    Post subject: fuel pump vent clearance |
				Randy,
 All good ideas. On my HR2 I made a small indentation in the firewall shelf to provide the clearance for the fitting. Worked great lasts a long time...
 Smokey
 On Dec 9, 2012, at 10:21 AM, "viperpilot" <nsage86(at)comcast.net> wrote:
  Randy Sage
  http://forums.matronics.com/viewtopic.php?p=390089#390089
				 Posted: Sun Dec 09, 2012 8:57 am    Post subject: fuel pump vent clearance |
				BTW Randy, I am a former Viper Pilot for 26 years, Dreams become reality when pursued fervently.
 Keep on dreaming!
 Smokey
  Randy Sage
		viperpilot
				 Posted: Sun Dec 09, 2012 10:16 am    Post subject: HRII Fuel Pump Vent Clearance |
				Smokey,
 Thanks! I wish I had a the room, now but it's all together.  Not an option I am afraid.
 Re Viper flyng, me too... 24 years of bliss! (well, except for the 4 years in the 5-sided puzzle palace!).
 Hope to fly with you some day...
