		viperpilot
  Joined: 28 Aug 2012 Posts: 11 Location: Peachtree City, GA
				 Posted: Sat Dec 08, 2012 2:20 pm    Post subject: HRII Fuel Pump Vent Clearance |
				I am finally returning my ship to flying status, having been aground for upgrades and fixes following a prop strike nearly a year ago.  Mounting the IO-540 with new elastic mounts has changed the clearance at the back of the engine a bit.  The engine-mounted fuel pump drain is uncomfortably close to the firewall.  The firewall has been dimpled inward a bit to increase clearance during the previous engine installation, but additional dimpling does not appear to be available due to the proximity of a vertical structural member on the cockpit side of the firewall.
 1.  Does anyone know of a method to increase clearance between the firewall and the fuel pump drain?
 2.  I have seen a few drain elbows of other aircraft that look to be smaller (or at least project aft less than the AN832-type fitting).  Are these available or are they custom made from an AN832-4?
 3.  Vans notes that the threads on the Lycoming fuel pump are "special" and that NPT threads will not work--does that note apply to the vent drain?
 4.  I assume that the vent drain only comes into play if there is a rupture in the fuel pump diaphram.  In that case, one is looking for fuel or oil coming from the vent drain as a major clue that the fuel pump is about to fail.  Is that an accurate statement?
 Any assistance or comment would be greatly appreciated.
 Randy Sage
 Peachtree City, GA
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
		stuart(at)stuarthutchison Guest
				 Posted: Sat Dec 08, 2012 3:27 pm    Post subject: HRII Fuel Pump Vent Clearance |
				G'day Randy,
 The vent thread is tapered and I'm pretty sure it's NPT.  The other fittings
 are straight thread, sealed by O-ring.
 I used a lathe, but the link  shows one option.  I ground the JB Weld flat
 of course.
 http://www.mykitlog.com/users/display_log.php?user=RockFLY&project=797&categ
 ory=5584&log=131278&row=53
 As you say, this should only vent fuel if the diaphragm is failing ... the
 intent is to stop fuel entering the crankcase through the hole where the
 actuator arm penetrates (top side of the diaphragm).
 Kind regards, Stu
 F1 Rocket    VH-FLY       http://www.mykitlog.com/RockFLY
 www.teamrocketaircraft.com
		hr2pilot(at)aol.com Guest
				 Posted: Sat Dec 08, 2012 3:29 pm    Post subject: HRII Fuel Pump Vent Clearance |
				Do away with the fitting
 On Dec 8, 2012, at 2:20 PM, "viperpilot" <nsage86(at)comcast.net> wrote:
  Randy Sage
  Peachtree City, GA
  http://forums.matronics.com/viewtopic.php?p=390071#390071
		viperpilot
				 Posted: Sat Dec 08, 2012 4:08 pm    Post subject: Re: HRII Fuel Pump Vent Clearance |
				Thanks guys!  Stuart's solution is certainly the most elegant, but simply removing the fitting would seem to work also, as there should be no fuel coming out of the port if all is well inside the fuel pump.  Seems like the only reason to have the drain line is to make it easier to ID the problem and I am sure the FAA required it for certification.
 Randy
		denis.walsh(at)comcast.ne Guest
				 Posted: Sun Dec 09, 2012 7:42 am    Post subject: HRII Fuel Pump Vent Clearance |
				Hey Randy
 I am not a viper pilot but I play one in my dreams frequently.  I could say the same about rockets.  I can dream anyway.
 In the dim reaches of my long term memory, I believe this is a long standing problem.  The RV 4 has a clearance problem which sounds like yours to me.  If so, Van's has a $9.50 solution. It is: Part Number = F OVERFLOW PLUG 1/8"
  Here is a link to the catalog:
 http://vansaircraft.com/cgi-bin/store.cgi?ident=1355067275-394-210&browse=engines&product=overflow-fitting
 Hope this helps.
 Denis
 On 8Dec, 2012, at 5:08 , "viperpilot" <nsage86(at)comcast.net> wrote:
  Randy
  http://forums.matronics.com/viewtopic.php?p=390080#390080
		ctlimited(at)hotmail.com Guest
				 Posted: Sun Dec 09, 2012 8:12 am    Post subject: HRII Fuel Pump Vent Clearance |
				Denis,That was great, I will be laughing all day about that one, Thanks.
  	  | Quote: | 	 		   Subject: Re: Re: HRII Fuel Pump Vent Clearance
  Date: Sun, 9 Dec 2012 08:42:21 -0700
  To: rocket-list(at)matronics.com
  --> Rocket-List message posted by: Denis Walsh <denis.walsh(at)comcast.net>
  Hey Randy
  Hope this helps.
  Denis
  > --> Rocket-List message posted by: "viperpilot" <nsage86(at)comcast.net>
  > Thanks,
  > Randy
  <b=
		viperpilot
				 Posted: Sun Dec 09, 2012 8:24 am    Post subject: Re: HRII Fuel Pump Vent Clearance |
				Denis!  My Man!!
 Randy
