Glideslope Antennas
philperry9
PostPosted: Wed Dec 05, 2012 8:32 am    Post subject: Glideslope Antennas Reply with quote
I haven't seen much discussion about the location for glideslope antennas and I'm going to need to make that decision sometime soon.
What seems to be the standard choice for antenna type and placement?   Also what type of results are you seeing?
Phil
#40750
Strasnuts
PostPosted: Wed Dec 05, 2012 8:43 am    Post subject: Re: Glideslope Antennas Reply with quote
http://www.aircraftspruce.com/catalog/avpages/comant157p.php
and
http://www.aircraftspruce.com/catalog/avpages/coupler507.php?clickkey=11684
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
philperry9
PostPosted: Wed Dec 05, 2012 8:49 am    Post subject: Glideslope Antennas Reply with quote
That sounds pretty easy.  Maybe that's why I never heard any discussion about it. Smile
On Wed, Dec 5, 2012 at 10:43 AM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote]--> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com (sean(at)braunandco.com)>
and
40936
http://forums.matronics.com/viewtopic.php?p=389905#389905
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
cooprv7(at)yahoo.com
PostPosted: Wed Dec 05, 2012 9:00 am    Post subject: Glideslope Antennas Reply with quote
I used the Bob Archer VOR wingtip antenna and the splitter mentioned below. Works great.
Marcus
40286
and
40936
Bob Turner
PostPosted: Wed Dec 05, 2012 9:55 am    Post subject: Re: Glideslope Antennas Reply with quote
As you are seeing, although it is possible to have a separate GS antenna (ever been in a Cessna with the bow tie antenna on the windscreen?) most people are using a VOR antenna with a splitter. If you have an SL30 it isn't even an option - it has a splitter built in for the GS, and the only input is for a VOR antenna.
I too use the Archer wingtip antenna, and it works great. It may have a directionally-dependent slightly reduced range for VORs, but I have heard no complaints about it when used for the localizer or GS.
Bob Turner
RV-10 QB
Strasnuts
PostPosted: Wed Dec 05, 2012 10:02 am    Post subject: Glideslope Antennas Reply with quote
There will be a bunch of combinations and personal opinions but just for reference I installed the Bob Archer in my wingtip for Nav 2 (SL30). My 430W is my NAV1 with the CI-157P on the vertical stab and it uses the diplexer. At 7000 feet I was averaging around 30-40 miles better reception on the cat whiskers than the Bob Archer.
780 Hours
SuperSTOL 60 hours
Bob Turner
PostPosted: Wed Dec 05, 2012 11:17 am    Post subject: Re: Glideslope Antennas Reply with quote
As the above post mentions, you will hear varying opinions on the Archer antenna. I think this is because it is somewhat installation dependent. However, I have not yet heard any negative comments about localizer or GS reception.
My data point: I did not follow Archer's instructions to the letter. From 7000' I routinely receive useable VOR signals (SL30) from 80 miles away - essentially line of sight to the horizon - except when the VOR is 90 degrees to the right, and the antenna has to "look" thru the fuselage. Then range is perhaps 40 miles.
Bob Turner
RV-10 QB
robin(at)PaintTheWeb.com
PostPosted: Wed Dec 05, 2012 11:27 am    Post subject: Glideslope Antennas Reply with quote
Me too.
Robin
EdKranz
PostPosted: Wed Dec 05, 2012 11:39 am    Post subject: Glideslope Antennas Reply with quote
This might be a stupid question, but if you are using a wingtip Bob Archer antenna for GS/LOC, would your position be offset by the 15' or so that the antenna is out from the centerline of the plane?
Is this something that you can compensate for in the NAV radio?
On Wed, Dec 5, 2012 at 1:27 PM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
[quote]--> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)>
Me too.
Robin
Ed Kranz
RV10
Finishing
www.edandcolleen.com
Tim Olson
PostPosted: Wed Dec 05, 2012 11:48 am    Post subject: Glideslope Antennas Reply with quote
No worries, Ed, all you do is fly 15' over to the left or right
a little. Smile You go try flying the approach to 15' lateral
accuracy and let me know when you've got it perfected. Smile
(sorry, couldn't resist...especially since it was you)
No not archive, no way, no how.
PostPosted: Wed Dec 05, 2012 12:10 pm    Post subject: Glideslope Antennas Reply with quote
I have an Archer style antenna (we mad ours) in both wing tips so I can flip between the two to get perfectly centered. Smile.
I just got my 200 Hp IO-360 to run LOP and got 152 KTAS at 5.8 GPH with a little tail wind I was getting 32 MPG. Yahoo!
Robin
Bob Turner
PostPosted: Wed Dec 05, 2012 12:12 pm    Post subject: Re: Glideslope Antennas Reply with quote
Ed is correct.
I put the antenna in the left wing tip so I am 15' to the right of the approach lights, making them easier to see out my (left) window!! -Smile
Bob Turner
RV-10 QB
EdKranz
PostPosted: Wed Dec 05, 2012 1:45 pm    Post subject: Glideslope Antennas Reply with quote
Good point, Tim. I had a hard enough time keeping your plane in the HITS boxes!
On Wed, Dec 5, 2012 at 1:48 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
om" target="_blank">www.aeroelectric.com
le, List Admin.
Ed Kranz
RV10
Finishing
dmaib@me.com
PostPosted: Wed Dec 05, 2012 2:26 pm    Post subject: Glideslope Antennas Reply with quote
I used the Comant that others have noted and it is mounted under the horizontal stab on the bottom of the tailcone. I have a splitter installed so that I can use it for the VOR/ILS/GS on both my SL-30 and my 430W. Works great. I can receive vor's on the SL-30 at 90 to 100 nm and usually about 60 nm on the 430W. ILS and GS reception is excellent on both.
David Maib
40559
Flying 600 hours.
Phil
#40750
David Maib
RV-10 #40559
New Smyrna Beach, FL
Mauledriver(at)nc.rr.com
PostPosted: Wed Dec 05, 2012 4:51 pm    Post subject: Glideslope Antennas Reply with quote
Me too. The Archer is shared by a G430 and SL30. Works fine. Only use
it for practice - in actual I'm 100% GPS.
I used an Archer for my Com2. I don't recommend doing that. When my
Com1 went intermittent (probably from an electrical storm) I found my
Com2 didn't work well enough to function as my primary Com. Since this
happened 3 legs from home, I had to swap antennas so my remaining com
was using a Comant whip. (Thanks again Kelly!)
The archer Com antenna is gone and a 2nd whip is now on my belly.
I went back and verified that the Archer Nav antenna performed well
enough approach work - it did. VOR reception varied side to side per
the findings by other posters.
I did follow the Archer installation instructions to a "T". The Com
works, just not good enough for a primary radio. And I learned that if
it won't do primary, then it really isn't a full backup.
On 12/5/2012 2:27 PM, Robin Marks wrote:
Me too.
Robin
philperry9
PostPosted: Wed Dec 05, 2012 5:07 pm    Post subject: Glideslope Antennas Reply with quote
I just got my panel in from Aerotronics last Friday and hadn't had a chance to dig through it closely yet.  Once I got home tonight, I looked a little more closely at the GTN750 and SL30.
Viola, there it was.  The splitter is already in place and connected to both radios.  Now I just have to connect the coax from the cat whiskers and I'm done.  What started off as a minor head scratcher turned into a remarkably simple issue.
Thanks everyone for pointing me in the right direction.
By the way, the panel looks even better in person than it does in pictures.  It exceeded my expectations by a long shot.  Can't wait to put electrons into it a few months from now.
Phil
On Wed, Dec 5, 2012 at 6:51 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Me too.  The Archer is shared by a G430 and SL30.  Works fine.  Only use it for practice - in actual I'm 100% GPS.
I used an Archer for my Com2.  I don't recommend doing that.  When my Com1 went intermittent (probably from an electrical storm) I found my Com2 didn't work well enough to function as my primary Com. Since this happened 3 legs from home, I had to swap antennas so my remaining com was using a Comant whip.   (Thanks again Kelly!)
I went back and verified that the Archer Nav antenna performed well enough approach work - it did.  VOR reception varied side to side per the findings by other posters.
I did follow the Archer installation instructions to a "T".  The Com works, just not good enough for a primary radio.  And I learned that if it won't do primary, then it really isn't a full backup.
[quote] --> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)>
Me too.
Robin
deej(at)deej.net
PostPosted: Thu Dec 06, 2012 10:04 am    Post subject: Glideslope Antennas Reply with quote
Hi Robin,
Where did you find the plans to make the wingtip NAV antenna? I am
very interested in doing the same.
-Dj
Dj Merrill - N1JOV
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Bob Turner
PostPosted: Thu Dec 06, 2012 12:13 pm    Post subject: Re: Glideslope Antennas Reply with quote
Due to thread drift I have started a new topic, "Archer antennas".
Bob
Bob Turner
RV-10 QB
deej(at)deej.net
PostPosted: Thu Dec 06, 2012 12:17 pm    Post subject: Glideslope Antennas Reply with quote
Turns out page 13-16 (Chapter 13, page 16) of the Aeroelectric
Connection has an excellent diagram:
https://matronics.com/aeroelectric/Catalog/pub/pub.html
-Dj
Dj Merrill - N1JOV
PostPosted: Thu Dec 06, 2012 1:04 pm    Post subject: Glideslope Antennas Reply with quote
Ha! good for you.
Robin
