sean(at)stephensville.com Guest
Posted: Fri Nov 30, 2012 11:17 am Post subject: Rear Baffle Positioning Tips? |
Any tips on getting the #5 and #6 rear baffles in place? I'm having
trouble even getting them in place for a test fit.
Should I remove the oil return lines on #5 and #6 to help?
-Sean #40303
n223rv(at)wolflakeairport Guest
Posted: Fri Nov 30, 2012 11:36 am Post subject: Rear Baffle Positioning Tips? |
I don't recall having to remove any lines, but I did have to do some funky bending to get it in place. It is not easy, but it should fit...
On Nov 30, 2012, at 2:15 PM, Sean Stephens <sean(at)stephensville.com> wrote:
Quote: |
Any tips on getting the #5 and #6 rear baffles in place? I'm having trouble even getting them in place for a test fit.
-Sean #40303
Kellym
Posted: Fri Nov 30, 2012 12:19 pm Post subject: Rear Baffle Positioning Tips? |
I just put mine on this morning. You have to wrestle #6 to get the inner
portion past the cyl head and engine mount, then it drops right in. #5
was easy by comparison. No issue with oil lines. Aim the cutouts for the
engine mounts right at the mount, and the curved portion angled a bit
towards the rear.
You will have to watch the oil return lines when you make the rods to
tie the bottom of front and rear baffles together a bit later in the plans.
-Sean #40303
Checked by AVG - www.avg.com
KCHD |
rleffler
You have to hold your tongue in the right position while pushing. ;^)
Actually, you've got to twist it a bit. It's hard to describe, but once you figure it out, you install and remove them pretty quick.
-Sean #40303
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
davidsoutpost(at)comcast. Guest
Posted: Fri Nov 30, 2012 12:20 pm Post subject: Rear Baffle Positioning Tips? |
Yeah. Massage them into position. No need to remove any lines.
David Clifford
RV-10 Builder
Howell, MI
From: "Michael Kraus" <n223rv(at)wolflakeairport.net>
Sent: Friday, November 30, 2012 2:34:43 PM
Subject: Re: Rear Baffle Positioning Tips?
--> RV10-List message posted by: Michael Kraus <n223rv(at)wolflakeairport.net>
Quote: | --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com>
-Sean #40303
-Matt Dralle, List Admin.<b================
Posted: Fri Nov 30, 2012 1:03 pm Post subject: Rear Baffle Positioning Tips? |
I can't get either to go in at all. Not sure why the plans say to
assemble these before putting them on. It seems it would be easier
before assembling the whole corner.
They aren't even close to going in and I'm scratching my rod covers on #6.
On 11/30/12 2:19 PM, Kelly McMullen wrote:
inner portion past the cyl head and engine mount, then it drops right
in. #5 was easy by comparison. No issue with oil lines. Aim the
cutouts for the engine mounts right at the mount, and the curved
portion angled a bit towards the rear.
plans.
> Thanks,
> -Sean #40303
Posted: Fri Nov 30, 2012 1:25 pm Post subject: Rear Baffle Positioning Tips? |
Ok, figured out #6. You need to take the oil cooler box off (un-cleco
it) from the assembly in order to allow it to flex more.
Now on to #5.
Thanks all...
-Sean
#6.
> plans.
>> Thanks,
>> -Sean #40303
> No virus found in this message.
jchang10
Posted: Fri Nov 30, 2012 1:29 pm Post subject: Rear Baffle Positioning Tips? |
Definitely put blue tape or something on to protect your rocker covers.
I probably had blue tape on mine for quite a while to protect scratching
from baffles as well as the cowl while fitting.
Jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
#6.
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
mdaniell
Posted: Fri Nov 30, 2012 1:30 pm Post subject: Re: Rear Baffle Positioning Tips? |
All of the above is true, however there was a post somewhere about a builder having difficulty with the oil cooler brace, I think it turned out to be the wrong part. If you're absolutely sure it won't fitthen maybe check you have the right part.
Posted: Fri Nov 30, 2012 2:26 pm Post subject: Rear Baffle Positioning Tips? |
The oil cooler brace fits fine. You just can't have it clecoed on the
baffle while you are trying to get the baffle in or the baffle doesn't
flex enough.
#5 is getting there, but my oil pressure valve (not sure what it's
really called) is in the way and the brace at the bottom of the baffle
hits the case a bit before getting into place. Going to have to mod
that a bit.
On 11/30/12 3:30 PM, mdaniell wrote:
http://forums.matronics.com/viewtopic.php?p=389634#389634
rene(at)felker.com Guest
Posted: Fri Nov 30, 2012 2:42 pm Post subject: Rear Baffle Positioning Tips? |
I had to mod mine for #5 to fit around the case and oil pressure valve.
Rene' Felker
N423CF
801-721-6080
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Fri Nov 30, 2012 4:24 pm Post subject: Re: Rear Baffle Positioning Tips? |
I loosened the oil return line on number 5.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Kelly McMullen
Posted: Fri Nov 30, 2012 6:03 pm Post subject: Rear Baffle Positioning Tips? |
Yes, I had the wrong part, a rear baffle intended for the RV-7, not the 10, which was about 1/8" too short.
I just mounted my baffles today. Yes, removing the oil cooler brace helps. Yes, it is a little tight with drain back tube on #5, but not hard to get that to fit. I found a little interference at crankcase is preventing my #5 from achieving correct position, so that screw holes at back of engine and brace line up. I think the plans should have called for assuring fit of all hardware before drilling the two holes for rear center brace. Oh well, just time and effort to make baffle fit the way it should.
On Fri, Nov 30, 2012 at 2:30 PM, mdaniell <martin.daniell(at)bigpond.com (martin.daniell(at)bigpond.com)> wrote:
[quote] --> RV10-List message posted by: "mdaniell" <martin.daniell(at)bigpond.com (martin.daniell(at)bigpond.com)>
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
