alternator b-lead bundled with engine computer wiring
rv8ch
PostPosted: Fri Jan 13, 2006 8:27 am    Post subject: alternator b-lead bundled with engine computer wiring Reply with quote
Hi Listers,
I'm trying to finalize my firewall penetrations,
and one convenient way would be to have one
"towel bar" type hole in the firewall with all
my wires. This would include the fat wire from
the alternator B-lead going back to the batteries
in the rear baggage area.
Do you expect any problems if I have all these
wires, including the wires from my engine computer
to my spark plug coils, fuel injector solenoids,
various crank position sensors, electric prop
controller, and various pressure transducers?
Many thanks for your advice!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
lhelming(at)sigecom.net
PostPosted: Fri Jan 13, 2006 10:52 am    Post subject: alternator b-lead bundled with engine computer wiring Reply with quote
That is how I did mine. Everything goes through one hole along with some
push pull cables. Just like Bob suggests. Minimize the number of FW
penetrations. I have the ACS2002 engine monitor with lots of wires. No
problems.
Indiana Larry, RV7 Tip Up SunSeeker 78 hours
N1deltawhiskey(at)comcast
PostPosted: Fri Jan 13, 2006 11:32 am    Post subject: alternator b-lead bundled with engine computer wiring Reply with quote
Mickey,
Don't understand why you are running the B-lead to the baggage area
batteries. How do you get power to the panel by running a lead from the
batteries to the panel/firewall area? If so, why not connect the B-lead to
that end of the buss?
Doug Windhorn
