bbradburry(at)bellsouth.n Guest
Posted: Thu Nov 29, 2012 2:50 pm Post subject: Using a Handheld radio to "Sniff" for RF leaks behind the |
I have a situation where the transponder, sometimes KMD150 moving map, and
sometimes TruTrak DigiflightII autopilot shut off when the Garmin DNS 430W
mike is keyed. I am assuming that I have a massive RF leak from the Garmin
coax that is causing this shutdown. I could be wrong because I have had
occasion where the transponder shut off for no apparent reason. I just
wanted to check for a leak.
I also plan to fab a coax that goes from the radio straight to the antenna
bypassing everything that it may be in proximity to in order to see if that
helps.
The more I think about this problem the more my head hurts!
Bill B
