kearney
Posted: Sun Nov 25, 2012 8:24 am Post subject: Maximum Climb Angle |
Hi
One of the things I need to do for my final inspection is ensure fuel flow with minimum fuel at the maximum climb angle.
Can anyone tell me what the maximum pitch angle is in a climb?
I will assume that the minimum fuel is whatever it takes to allow fuel to flow at that angle. Anyone have an idea of what that might be?
Cheers
Les
#40643 - CGCWZ
So close, oh so close….. [quote][b]
Tim Olson
Posted: Sun Nov 25, 2012 9:19 am Post subject: Maximum Climb Angle |
I'd say it FEELS like 70 degrees or so.
But, it's probably more like 30-35 as a max, as a
norm it's probably much less yet.
Tim Olson - RV-10 N104CD
On 11/25/2012 10:23 AM, Les Kearney wrote:
| Quote: | Hi
Can anyone tell me what the maximumpitch angle is in a climb?
I will assume that theminimumfuel is whatever it takes to allow fuel to
flow at that angle.Anyone have an idea of what that might be?
Cheers
Les
#40643 - CGCWZ
Soclose, oh so close…..
partner14
Posted: Sun Nov 25, 2012 10:40 am Post subject: Maximum Climb Angle |
Actually if you think about it, it's backward... with minimum fuel you should want to know what is the maximum decent angle... cause with minimum fuel, you should be coming down, not going up. Just kidding here.
Probably a bigger consideration would be which tank are you on when low on fuel in the pattern? Better be on the opposite tank as the pattern direction.... and that may not be the fullest tank.
Don McDonald
Sent: Sunday, November 25, 2012 11:18 AM
Subject: Re: Maximum Climb Angle
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
| Quote: | Hi
Cheers
Les
#40643 - CGCWZ
p; * The Builder's Bookstore wwwp; -Mor?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-Lisreat content also available via the Web =============
40636 |
kearney
Posted: Sun Nov 25, 2012 10:54 am Post subject: Maximum Climb Angle |
Don
Quite true and good info to have. On the other hand this is a very specific info requirement that I have to satisfy.
Cheers
Les
On 2012-11-25, at 11:40 AM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote]Actually if you think about it, it's backward... with minimum fuel you should want to know what is the maximum decent angle... cause with minimum fuel, you should be coming down, not going up. Just kidding here.
Don McDonald
From: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
| Quote: | Hi
Cheers
Les
#40643 - CGCWZ
[url=http://wwmebuiltHELP <a target=] [/url]
[url=http://wwmebuiltHELP <a target=] [/url] | Quote: |
" face="courier new,courier">www.aeroelectric.com
| Quote: | www.buildersbooks.com
uilthelp.com
matronics.com/contribution
://www.matronics.com/Navigator?RV10-List
cs.com
rv10flyer
Posted: Sun Nov 25, 2012 12:00 pm Post subject: Re: Maximum Climb Angle |
Have a couple of people hold your tail down onto your tie down. That will get you close. I was getting 42 gph with a 15' hose connected to fuel line from servo inlet.
Also if you like to slip instead of crab during xw landings, you will want to be on the downwind tank. It may or may not be the tank opposite the pattern direction.
_________________ Wayne G. |
Posted: Sun Nov 25, 2012 1:28 pm Post subject: Maximum Climb Angle |
You could calculate based on VS & airspeed. At sea level low on fuel, max could be 2,000fpm at 110kias. You could calculate the angle based on that and do your measurement. In coordinated flight, it doesn't matter which tank versus which way you turn, but when I'm low I hold some rudder from the side that I am burning, but that doesn't affect your test. The benefit for you is that the pickup is at the back of the tank, so you will burn much lower before sucking air than in level flight. Note, though, that you want to set minimum fuel in a level situation to get an accurate reading of the fuel level. With the tail on the ground you may get a couple of gallons after your gauge reads empty.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Nov 25, 2012, at 11:23 AM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] Maximum Climb Angle
Hi
Cheers
Les
#40643 - CGCWZ
So close, oh so close….. | Quote: |
ctric.com
uilthelp.com
cs.com
Bob Turner
Posted: Sun Nov 25, 2012 3:20 pm Post subject: Re: Maximum Climb Angle |
"Probably a bigger consideration would be which tank are you on when low on fuel in the pattern? Better be on the opposite tank as the pattern direction.... and that may not be the fullest tank. "
This is an OWT. As long as you fly coordinated turns, it makes no difference. Uncoordinated - as in a cross wind landing - it might be best to have fuel from the higher tank.
_________________ Bob Turner
RV-10 QB |
johngoodman
Posted: Sun Nov 25, 2012 8:19 pm Post subject: Re: Maximum Climb Angle |
Les,
Since the RV-10 is non-acrobatic, there is no need to know that number. Also, the only reason that would come into play is doing a hot-shot snap up into a break when you're almost out of gas - an opportunity to get a Darwin Award. (g)
You mentioned: "On the other hand this is a very specific info requirement that I have to satisfy."
If that info requirement is a limitation you want to put in your POH, I'd advise against it.
[quote="kearney"]Hi
Cheers
Les
#40643 - CGCWZ
Gordon Anderson
Posted: Mon Nov 26, 2012 12:08 am Post subject: Maximum Climb Angle |
Les,
The requirement is from FAR 23.955 paragraph (a). You are looking for the highest angle of the fuselage to horizontal, which gives the highest likelihood of uncovering the pickup tube and/or running into vapor lock issues. This is not the same as the maximum flight path angle the plane can climb at, which would be just over 10° based on Jesse's numbers.
IIRC airfoils for GA aircraft typically stall somewhere around 12-17° incidence, but this depends a lot on aspect ratio and flap configuration. I can see two ways of getting the real number. First is to ask Vans. Second is to persuade one of our bold test pilots out there to measure the inclination angle of the tunnel cover at onset of stall in a climb. (Conveniently, there is an iPhone app for measuring angle;-) ). Good luck with either method!
Tying the tail to the floor with the mains on the ground will give you just over 15°. You could always ask if your inspector would accept that.
Gordon
Hi
Cheers
Les
#40643 - CGCWZ
href="http://www.aeroelectric.com/">www.aeroelectric.com
href="http://www.buildersbooks.com/">www.buildersbooks.com
href="http://www.homebuilthelp.com/">www.homebuilthelp.com
glastar(at)gmx.net Guest
Posted: Mon Nov 26, 2012 4:40 am Post subject: Maximum Climb Angle |
Gordon and Les,
here in Switzerland that test is required to be done on 16 degrees angle
of attack, but be aware there might be a 2nd critical angle on a decent
where your tank might unport on a steep decent. Not so much a danger
with the narrower tank of our 10 more of a wider tank like in my
Glastar, or like on of our members found out on his Wheeler Express over
Insbruck.
Cheers Werner
On 26.11.2012 09:07, Gordon Anderson wrote:
| Quote: | Les,
Gordon
> Maximum Climb Angle
> Hi
> to flow at that angle.Anyone have an idea of what that might be?
> Cheers
> Les
> #40643 - CGCWZ
> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
> href="http://forums.matronics.com/">http://forums.matronics.com
rv10flyer
Posted: Mon Nov 26, 2012 4:57 am Post subject: Re: Maximum Climb Angle |
Minimum fuel for testing on the ground...I believe I may have had 8 oz. remaining when pump cavitated. Now flying I have had one tank with 5 and one with 7 remaining after 750 nm/4.5 hr flight. 5 gal per side is my personal minimum. I did not have to do the test for the FAA Insp, but more for my piece of mind.
TimRVator(at)comcast.net Guest
Posted: Wed Nov 28, 2012 4:34 pm Post subject: Maximum Climb Angle |
Not the answer, but a data point: I see up to about 15 degrees pitch up
(EFIS reference w.r.t. cruise pitch) at best rate of climb (takeoff).
Best angle would be steeper.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 350 hrs
Les Kearney said the following on 11/25/2012 11:23 AM:
| Quote: | Maximum Climb Angle
Hi
Cheers
Les
#40643 - CGCWZ
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Thu Nov 29, 2012 8:23 pm Post subject: Re: Maximum Climb Angle |
Why would anyone need this data point? Who in their right mind would do a maximum climb with ounces of fuel? A standard test is to ensure that the pump can deliver at a high angle of attack, not with "minimum fuel". These pumps don't cavitate from lack of head, they stop pumping when the suction line is uncovered. So all you need to do is check that the pump works (ie, delivers 24 gph or so) at a high angle. This is physically limited by how far you can tie the tail down (unless you dig a hole - not recommended). So just tie the tail down as far as it will go and don't worry what the angle may be. This test is worth doing.
A separate test for minimum fuel (or measuring unusable fuel - same thing) is done in a level attitude. Also worth doing.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
