dosmythe(at)cox.net Guest
Posted: Tue Jun 06, 2006 10:48 am Post subject: Ethanol Question |
All,
I've been reading about this Ethanol gasoline and the fact that it will "Phase Separate" if too much water is present in the fuel. Someone mentioned this the other day and I had no idea what he was talking about. One article on the Rotax 582 said that if phase separation occurs then you have a good amount of combined water/ethanol laying somewhere in your system which won't burn. Also, once phase separation occurs you will loose about 3 points on the octane rating. So, 93 octane would be about 90 octane.
This is really reaching out there but, what if a person built himself a rig where he could pour in say 5 gallons of gasoline w/ 10% ethanol and "ADD" 1 gallon of water. Stir slowly and allow to sit for a period of time. Design the rig so that the bottom portion would be small like a funnel and have a valve located above the accumulated water/ethanol line. Once the phase separation occurs and all settles, shut the valve and drain off the water/ethanol. You end up with pure gasoline minus 3 octane.
What do some of you Chemical Engineers think? I'm willing to test anything.
Don Smythe
Too much time on my hands.
kerrjohna(at)comcast.net Guest
Posted: Tue Jun 06, 2006 12:07 pm Post subject: Ethanol Question |
interesting concept, Don
| Quote: | -------------- Original message --------------
All,
Don Smythe
rjdaugh(at)rapidnet.com Guest
Posted: Tue Jun 06, 2006 12:19 pm Post subject: Ethanol Question |
Don,
The basics of what you suggest will work. BUT,,,,
You are at risk of making a mistake and loading your tank with a little water if you don’t get a good clean phase separation. Also, as it cools(cold weather flying), more aqueous layer will separate out. – stuff that was in the gasoline layer at room temperature. Even with the phase separation, there is some ethanol and water in the gasoline layer and some gasoline in the aqueous layer.
Also, the addition of oil may cause some more water/ethanol layer to separate out. (If you are feeding a 2-stroke.)
And the last thing that comes to mind immediately is that the difference of 3 octane points may not be precise. In other words sometimes more than 3 points loss, sometimes less.
And then you will have some gasoline contaminated vodka to dispose of. Don’t drink it!
But it is a great idea. Just not one that I would fly behind.
Randy
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Don Smythe
Sent: Tuesday, June 06, 2006 12:44 PM
To: Kitfox List
Subject: Ethanol Question
All,
Don Smythe
Posted: Tue Jun 06, 2006 4:06 pm Post subject: Ethanol Question |
Randy,
I use an old saying, "For every good idea on a Kitfox there are a dozen things (you didn't think of) that will come out and bite you in the rear. You sound like you have some very good knowledge on this subject so I think I'll go with plan "B". However, I don't have a plan "B" right at this moment. Another old saying, "There is a way"
BTW, is there a method to insure a better clean phase separation so that flying behind might be safer? I'm talking about a method that can be home made.
Don Smythe
Posted: Wed Jun 07, 2006 6:15 am Post subject: Ethanol Question |
what about conducting the process at or below 32 degrees?
(at)font-face { font-family: Tahoma; } (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: #606420; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: #606420; TEXT-DECORATION: underline } P.MsoAutoSig { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoAutoSig { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoAutoSig { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } SPAN.EmailStyle17 { FONT-WEIGHT: normal; COLOR: blue; FONT-STYLE: normal; FONT-FAMILY: Arial; TEXT-DECORATION: none } DIV.Section1 { page: Section1 } Randy,
Don Smythe
Posted: Wed Jun 07, 2006 7:32 am Post subject: Ethanol Question |
Don,
This is a common chemical process operation. In correctly designed equipment it can be consistently successful if certain complications don’t appear. Also, chemical plants have analytical QC labs to keep an eye on the process.
The worst complication is contamination with surfactants (soaps or detergents) that stabilize emulsions. Milk is a stable emulsion. It should separate into two layers, but it doesn’t (Usually!). Gas companies often have additive packages that they add to gas so they can justify charging high prices. – maybe to keep fuel injectors clean…. If these stabilize the emulsion, you will have a hard time getting phase separation.
It is an intriguing idea. Maybe we should be entrepreneurial and design small units to locate at FBO’s. These could be complete with instructions, small QC kits and mole sieves swing units to dry the gas after separation. (This would make the gas safe to use a cold temperatures.) But it might be easier to buy the gas BEFORE they add the alcohol.
Randy
Sent: Tuesday, June 06, 2006 6:02 PM
Subject: Re: Ethanol Question
Randy,
Don Smythe
mike Guest
Posted: Wed Jun 07, 2006 9:15 am Post subject: Re: Ethanol Question |
let me ask these questions, is this problem mainly because of the use of a 2 stroke and the other, is the problem because the fuel will be sitting too long, hence old fuel. Answer to both, first the four stroke and second, fly two hours a day.
Posted: Wed Jun 07, 2006 10:52 am Post subject: Ethanol Question |
I'm concerned that Ethanol might cause damage to many components of both 2
and 4 stroke systems. For example, I just purchased new filters elements w/
"O" rings for the Puralator glass filters. Are the "O" rings compatible
with Ethanol??? How about the diaphragm in the Mik fuel pumps??? Not to
mention the fiberglass tanks, low fuel sensors, gascalators, fuel primer
and the list goes on.....
Don Smythe
kitfoxpilot(at)msn.com Guest
Posted: Wed Jun 07, 2006 10:57 am Post subject: Ethanol Question |
I thought the big problem with ethanol or the like was it would disolve the
coating in the fiberglass tanks thus causing them to leak!
Ray
[quote]From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Subject: RE: Ethanol Question
Date: Wed, 7 Jun 2006 09:31:23 -0600
Don,
equipment it can be consistently successful if certain complications don't
the
process.
should
separate into two layers, but it doesn't (Usually!). Gas companies often
high prices. - maybe to keep fuel injectors clean.. If these stabilize
the
small units to locate at FBO's. These could be complete with instructions,
Randy
_____
Randy,
dozen
that
made.
Don Smythe
mike Guest
Posted: Wed Jun 07, 2006 12:53 pm Post subject: Re: Ethanol Question |
I went and changed all my hoses to injection hose, ff, I only have clear paper filters, ya I know, but I change them every oil change, cheap. I regularly check the carbs for water, I'm constantly checking all systems on the airplane, I replaced the fuel pump at the ending of last year(600hrs) didn't want to trust it anymore. I did ask lockwood if the pump was ok for ethanol and they said it was safe. I have the blue hose where there isn't steel line from the tanks to the firewall and injection line from there to the rest. I fly on the average of 50hrs a month and I haven't had any trouble. When I fly in the winter I switch to 100ll and tcp.
lcfitt(at)sbcglobal.net Guest
Posted: Wed Jun 07, 2006 2:18 pm Post subject: Ethanol Question |
Don,
All valid issues. I remember while in the early building phase, skystar
offered replacement o-rings for the fuel valve - Viton for the supplied
N-Buna for those using Mogas. My guess is that since the filter you are
using is designed for mogas it will be compatible.
I just went on line to find a metric o-ring for a pressure washer. O-rings
are available in numerous materials and cheap. The $.75 o-ring locally goes
for $8.00 per fifty on line. A friend here has the dimensions of the Rotax
rocker cover o-rings and they are pennies compared to the dollars for the
"genuine" Rotax part. Can't help with the diaphragms and other proprietary
parts, but since there are so many Rotax engines out there - Seadoo, Skidoo
and aviation, my gurss is that rather than Rotax having all these engines
retired, they are hard at work developing servicable parts.
Lowell
Posted: Wed Jun 07, 2006 2:38 pm Post subject: Ethanol Question |
Lowell old Buddy,
You are probably right but it doesn't hurt to get a little curious on
these issues and beat them to death a bit. I believe that some parts of the
US have been using Ethanol for some time. Are there people out there
pumping Gasoline W/10% Ethanol and having no problems?
Was talking to a guy yesterday that has an auto fuel STC for his Cessna.
He's still buying auto gas like crazy with 10% Ethanol. I believe the STC
say's, "NO" Ethanol and if Ethanol is all you can get you must switch back
to 100LL.
Don Smythe
gofalke(at)sbcglobal.net Guest
Posted: Wed Jun 07, 2006 3:49 pm Post subject: Ethanol Question |
Don, and all other 10% ethanol users:
I am using this stuff for over 4 years without any problems in the Chicago area.
Herbert Gottelt
Mount Prospect, IL
M4-1200,912UL.
Don Smythe <dosmythe(at)cox.net> wrote:
[quote]--> Kitfox-List message posted by: "Don Smythe"
Lowell old Buddy,
Posted: Wed Jun 07, 2006 4:21 pm Post subject: Ethanol Question |
Herbert,
Thanks, I guess that's good news. I assume you've been using the 10% ethanol?
How about any 2 strokers with a similar report?
Don Smythe
rliebmann(at)comcast.net Guest
Posted: Wed Jun 07, 2006 7:02 pm Post subject: Ethanol Question |
I live by Herb and I have been using 10% ethanol for years too with no effect on my tanks or performance. I fly a greyhead 582.
Ron N55KF
