ECI Pushrod Shroud Retainer
Tim Olson
PostPosted: Wed Nov 28, 2012 12:37 pm    Post subject: ECI Pushrod Shroud Retainer Reply with quote
Not sure if others got this or not, but just one part to
check out if you have used an ECI parts kit at all, or
happen to have an ECI retainer clip from some maintenance.
http://eci.aero/pdf/12-1.pdf
Just one of those little things...
rv10flyer(at)live.com
PostPosted: Wed Nov 28, 2012 1:11 pm    Post subject: ECI Pushrod Shroud Retainer Reply with quote
I called Eci, good folks! the stock was changed in July 2010. Basically if
there was a problem one would know rather quickly in the form of a oil leak.
I explained I had over 100 hours and he suggested that it was quite remote
at this point to have an issue, which means I probably had the engine built
with different retainer clips.
If you have had the engine less than 2 years this should not apply to you.
Mauledriver(at)nc.rr.com
PostPosted: Wed Nov 28, 2012 2:57 pm    Post subject: ECI Pushrod Shroud Retainer Reply with quote
Some clarification please. Is this an aftermarket part that would not
be found on a new stock Lycoming?
Thanks as always,
Bill
PostPosted: Wed Nov 28, 2012 3:07 pm    Post subject: ECI Pushrod Shroud Retainer Reply with quote
Eci cylinders are an option that are put into experimental engines.
Mattituck, Penn Aero, America's, etc may us them when they build an engine
for a builder (overhauled, rebuilt).. Lycoming has their own cylinders so
not an issue for stock Lycoming.
