Mounting fuse blocks
dmasys(at)cox.net
PostPosted: Mon Jun 05, 2006 3:58 pm    Post subject: Mounting fuse blocks Reply with quote
If you happen to be using the Aeroelectric approach of using fuse blocks instead of (or along with) breakers, one way of mounting the fuse holders so they are out of the way but accessible when needed is to put them on a hinged panel between the panel and subpanel. Just got mine cut and installed. These pics show the essential buss block (20 fuse positions), main block (10 position) and battery block (6 position), separated by the diode mounted to a heat sink from B&C specialties:
Seen from above:
http://132.239.155.44/rv10/2006-06-05_fuseblockmount.jpg
and below, where a Dzus cowl fastener keeps the plate in place
http://132.239.155.44/rv10/2006-06-05_fuseblockmount_b.jpg
One half twist of the cowl fastener the the plate drops down vertically for access to the fuses.
-Dan Masys
#40448
ron.mcgann(at)baesystems.
PostPosted: Mon Jun 05, 2006 4:08 pm    Post subject: Mounting fuse blocks Reply with quote
Dan
Precisely what I was about to do (including fuse block selection) - thanks for the pics.  But man, that is one BIG heatsink Smile
Ron
dmasys(at)cox.net
PostPosted: Mon Jun 05, 2006 6:49 pm    Post subject: Mounting fuse blocks Reply with quote
It's the standard heatsink/diode combination that comes from B&C. On my RV-7 I just mounted the diode to some 0.063 plate and it got so hot it melted in the insulation on the downstream wire! (Also showed increasing internal resistance with heat, so the voltage would drop on the e-Bus). Live and learn.
-Dan Masys
---- "McGANN wrote:
Dan
Ron
KiloPapa
PostPosted: Mon Jun 05, 2006 9:44 pm    Post subject: Re: Mounting fuse blocks Reply with quote
Looks nice. Where did you get the fuse blocks?
Kevin
40494
jesse(at)itecusa.org
PostPosted: Tue Jun 06, 2006 2:55 am    Post subject: Mounting fuse blocks Reply with quote
Very nice.
Jesse
Seen from above:
-Dan Masys
#40448
Jesse Saint
I-TEC, Inc.
www.itecusa.org
rvreynolds(at)macs.net
PostPosted: Tue Jun 06, 2006 4:03 am    Post subject: Mounting fuse blocks Reply with quote
Have you checked access with the brakes installed?
Richard Reynolds
Norfolk, VA
PostPosted: Tue Jun 06, 2006 5:12 am    Post subject: Mounting fuse blocks Reply with quote
That looks like it is from the bulkhead to the panel support, so it should
be aft of the brakes. The only problem in-flight would be getting your legs
out of the way so you could flip it down, but in most cases where you are
blowing a fuse, putting another one in is probably not going to fix the
problem. The blown fuse is just evidence that there is a problem that needs
to be fixed.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Ray.R.Doerr(at)sprint.com
PostPosted: Tue Jun 06, 2006 5:18 am    Post subject: Mounting fuse blocks Reply with quote
            I did the same thing but installed mine on the pilot side because I had my heater controls on the right side and they go through the lower switch panel and then under the sub-panel.  You may have to think about where you are planning to install all you push/pull cables for stuff like Alternate Air, Parking Brake and Front and Rear Heat.
Thank You
Ray Doerr
40250
N519RV (28 hours on it now)
Rick S.
PostPosted: Tue Jun 06, 2006 5:51 am    Post subject: Mounting fuse blocks Reply with quote
I'm using the one with the heatsink, I have not powered it up but are you saying the voltage drop has been resolved by using the heatsink or is is specific to the unprotected diode?
Rick S.
40185
Rick S.
RV-10
40185
brinker(at)cox-internet.c
PostPosted: Tue Jun 06, 2006 5:54 am    Post subject: Mounting fuse blocks Reply with quote
I was considering something similar but after reading some on the
Aeroelectric list and from my experience with automobile fuses is just as
you have said. Most of the time no need to replace a blown fuse until the
problem itself is fixed. Although would be nice to have access to them
during flight. Oh decisions decisions.
Randy
dmasys(at)cox.net
PostPosted: Tue Jun 06, 2006 8:40 am    Post subject: Mounting fuse blocks Reply with quote
Yes, it is fine with respect to the brakes. Lots more room in the -10 than in the two place forward fuselage. Originally got the idea from Andy Karmy whose installation in his -9A is shown here:
http://www.karmy.com/rv9a/pictures/fuselage/electrical/img_0022.htm
-Dan Masys
Richard Reynolds
Norfolk, VA
dmasys(at)cox.net
PostPosted: Tue Jun 06, 2006 8:45 am    Post subject: Mounting fuse blocks Reply with quote
B & C specialty products has all of the stuff one needs to wire up a plane by the Aeroelectric ('lectric Bob) approach:
Fuse blocks are at:
http://www.bandcspecialty.com/cgi-bin/ez-catalog/cat_display.cgi?7X358218
TerminalTown also has them at:
http://www.terminaltown.com/Pages/Page204.html
Hope this helps,
-Dan Masys
Kevin
40494
http://forums.matronics.com/viewtopic.php?p=38870#38870
dmasys(at)cox.net
PostPosted: Tue Jun 06, 2006 8:54 am    Post subject: Mounting fuse blocks Reply with quote
In my -7A the heat-sinked diode has a constant voltage drop (about 0.8 volts) between main buss and e-buss. The old diode, mounted to the plate with the fuseblocks but not separately heat-sinked, would start with a 0.8 volt drop, but as load was added to the e-bus (in particular the TruTrak autopilot, whose load varies with the amount of turbulence due to stepping motor activity and can be up to 7.5a) the voltage drop would go as high as 2.5 volts as it heated up, causing low voltage alarms from the Grand Rapids EIS, which was powered from the e-Bus. Would also occasionally cause the transponder to hiccup. Not a good scene.
-Dan
Rick S.
40185
pitts_pilot(at)bellsouth.
PostPosted: Tue Jun 06, 2006 9:02 am    Post subject: Mounting fuse blocks Reply with quote
to be fixed.
And while you're preoccupied with the fuses, you aren't flying the
plane, checking for traffec etc.!!! Best to wait 'till you're back on
solid ground. IMHO, of course Smile
Linn
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
