Harv
Posted: Mon Oct 15, 2012 7:35 am Post subject: CJ6 primer |
Gents
Fuelled my CJ for the first time last week since import in 2006.
Fuel lines primed and the engine has run (with an awful oil leak from behind the prop dome) but the primer handle is sooooo stiff it takes all the might you have to move it.
Any ideas what causes this or if the seals inside it can be changed?
Rgs
Posted: Mon Oct 15, 2012 10:07 am Post subject: CJ6 primer |
Order a set of prop seals from Doug and replace the ones in the prop hub
piston. Most likely the old ones are simply deteriorated.
Assuming you do mean the primer pump on the right side by your elbow,
there is one seal inside which can be replaced. I'm sure Doug has them
in stock as well. Remove the knurled nut below the primer and turn the
knob to the left or right as if you were going to prime the engine. You
can then extract the primer pump from the female end which remains
affixed to the console. Disassemble the primer pump plunger by removing
the screw in the center of the knob and slide everything off the
plunger, including the old seal. Reverse the procedure to reassemble
and install in the female end.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 10/15/2012 10:35 AM, Harv wrote:
Gents
Rgs
http://forums.matronics.com/viewtopic.php?p=385364#385364
rijaeger(at)wausau.k12.wi Guest
Posted: Mon Oct 15, 2012 10:35 am Post subject: CJ6 primer |
You have to be substantially familiar w/ an aircraft to spit out specifics like that.
How many of you think Dennis should get some kinda PLAQUE? All those in favor, say "Aye!" Talk about the "man w/ the plan." I will never forget disassembling my newly-purchased Yak ALONE and outdoors on a chilly November Saturday last November at Flying W and hitting a "wall" w/ the process as I pondered the early dusk and the nearly 1200 miles I had to drag the thing back. After about a 90 second call to Dr. Dennis I was on my way once again w/ the tools he specified (as well as sizes and physical positioning) and the "wall" was gone. I'm sure I don't need to say this to anyone, but there's a BIG difference between a "know-it-all" and someone who honestly knows it all. There are some mighty helpful people on this list, but - in my book - Dennis takes the cake! Thanks, Dennis - for ALL you do!
On Mon, Oct 15, 2012 at 1:04 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote]--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Order a set of prop seals from Doug and replace the ones in the prop hub piston. Most likely the old ones are simply deteriorated.
Assuming you do mean the primer pump on the right side by your elbow, there is one seal inside which can be replaced. I'm sure Doug has them in stock as well. Remove the knurled nut below the primer and turn the knob to the left or right as if you were going to prime the engine. You can then extract the primer pump from the female end which remains affixed to the console. Disassemble the primer pump plunger by removing the screw in the center of the knob and slide everything off the plunger, including the old seal. Reverse the procedure to reassemble and install in the female end.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
| Quote: | --> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
Gents
Rgs
======================o browse
s.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List
======================ttp://forums.matronics.com/" target="_blank">http://forums.matronics.com
====================== -Matt Dralle, List Admin.
Rico Jaeger
Choir / East High
General Music / Mann
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Mon Oct 15, 2012 10:48 am Post subject: CJ6 primer |
I say Aye
I agree with you
Not only Dennis but he particularly has got a special mention from us in Paris - France because he is always eager to help.
Thanks Dennis thanks so much.
Didier Blouzard+33(0)6 5184 4802
Le 15 oct. 2012 à 20:33, Rico Jaeger <rijaeger(at)wausau.k12.wi.us (rijaeger(at)wausau.k12.wi.us)> a écrit :
[quote]You have to be substantially familiar w/ an aircraft to spit out specifics like that.
| Quote: | --> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Gents
Rgs
Rico Jaeger
Choir / East High
cs.com
matronics.com/contribution
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
Posted: Mon Oct 15, 2012 10:57 am Post subject: CJ6 primer |
Your are way to kind Rico.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 10/15/2012 1:33 PM, Rico Jaeger wrote:
| Quote: | You have to be substantially familiar w/ an aircraft to spit out
between a "know-it-all" and someone who honestly *knows it all*. There
<dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com <http://www.yak-52.com/>
Skype - Yakguy1
<mailto:martin.harvey(at)kbr.com>>
Gents
changed?
Rgs
Rico Jaeger
Choir / East High
Posted: Mon Oct 15, 2012 11:00 am Post subject: CJ6 primer |
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 10/15/2012 1:46 PM, Didier BLOUZARD wrote:
| Quote: | I say Aye
I agree with you
Didier Blouzard
+33(0)6 5184 4802
> difference between a "know-it-all" and someone who honestly *knows it
> all*. There are some mighty helpful people on this list, but - in my
> Dennis
> A. Dennis Savarese
> 334-285-6263
> Skype - Yakguy1
> Gents
> changed?
> Rgs
> s.com/Navigator?Yak-List <http://s.com/Navigator?Yak-List>"
> Rico Jaeger
> Choir / East High
> cs.com
cjpilot710(at)aol.com Guest
Posted: Mon Oct 15, 2012 1:17 pm Post subject: CJ6 primer |
Put some oil on it. "Mouse Milk" or something similar. You will need to do this occasionally anyway. Try that first.
Jim "Pappy" Goolsby
In a message dated 10/15/2012 11:56:20 A.M. Eastern Daylight Time, martin.harvey(at)kbr.com writes:
| Quote: | --> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com>
Gents
Rgs
Posted: Mon Oct 15, 2012 1:29 pm Post subject: CJ6 primer |
Based on what he said it has been sitting for 6 years. So spend $5-6
and replace the darn thing. It's probably dry-rotted anyway. He's got
to order a new seal kit for the prop hub. So why not just include the
primer pump flat o-ring too?
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 10/15/2012 4:14 PM, cjpilot710(at)aol.com wrote:
| Quote: | Put some oil on it. "Mouse Milk" or something similar. You will need
Jim "Pappy" Goolsby
Gents
Rgs
Harv
Posted: Tue Oct 16, 2012 3:50 am Post subject: CJ6 primer |
Are you absolutely certain the inner prop piston seal was correctly
installed when you replaced them? If you pull the prop hub dome and
piston and look inside the hub, do you see oil lying inside the hub? If
there is oil inside the hub, either the small, inside seal was put in
backwards or the oil is leaking in to the hub from the back end
(threaded end) of the oil tube. The inside of the hub should be dry.
No oil whatsoever.
Did you replace the blade collett seals? These seals are located on the
inside of the large castellated nuts on the side of the hub. You must
unscrew the blades, remove the counterweight clamps and remove the large
castellated nut on each side. Then remove, clean and repack the large
bearings, the race for the inside bearing and the slider. The seals are
usually in the hub seal kit.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 10/16/2012 6:00 AM, Harv wrote:
Gents
Thanks for the input.
Yes i meant the engine fuel primer. I do think i have a seal kit from Doug already on the shelf so i'll pull the thing appart as per Dennis's instructions and replace it. Wlll also lubricate upon re-assembly. Not sure what mouse milk is but I have some white grease I could use.
The prop seals were replaced, upon further inspection the leak seems to be coming from the root of prop blades (not the dome seal).
Rgs
http://forums.matronics.com/viewtopic.php?p=385438#385438
barryhancock
Posted: Wed Oct 17, 2012 8:53 pm Post subject: Re: CJ6 primer |
While I agree that the seal probably could use replacing based on the stated information, also remember that the collar nut that secures the assembly effects how much friction is on the primer. If it is gorilla tight, it can certainly make the primer a bugger to operate. Make sure that has proper tension, also.
Happy Flying,
Barry
_________________ Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com |
Harv
barryhancock
Posted: Mon Nov 12, 2012 7:45 am Post subject: Re: CJ6 primer |
I'm thrilled to hear it was an easy fix! Now, the other side of this equation is that if the collar nut is too loose, the primer will leak fuel. Just FYI...
It's 22 degrees with a white blanket as far as they eye can see here. Beautiful, but not exactly Stearman weather....
Happy Flying to those of you in warmer climes!
Barry
