paul.zimmer00(at)gmail.co Guest
Posted: Sun Nov 11, 2012 5:57 pm Post subject: EBUS Circuit Protection |
I didn't include circuit protection for my EBUS, that is powered through a B&C Essential bus diode. The best explanation for not doing so is that it seemed unnecessary at the time I was designing the electrical system, and protection was not called for in the Z-12 drawing after which my electrical system in based. I am second guessing myself now, especially given the documentation that comes with the EBUS diode shows a breaker (not to exceed 25A).
As far as I can reason, the only purpose for circuit protection would be to protect the diode itself. If the diode was not present and the bus bar that is the EBUS was simply an extension of the Main bus, circuit protection between the bus bars would not be called for.
Would you recommend adding circuit protection between EBUS and main bus? Will the Essential Bus Diode open if its current rating is sufficiently exceeded, or will it allow current to pass (albeit in both directions)? It seems that circuit protection would be a good thing since you would have no good way to tell if the diode had been compromised (unless of course it opened after being sufficiently abused).
Thanks in advance for your help.
Paul
Posted: Mon Nov 12, 2012 7:25 am Post subject: EBUS Circuit Protection |
The legacy philosophy for circuit protection
in airplanes says fuses and breakers are to prevent
fire/smoke from wires. That doesn't mean that some
system designer/integrator might deduce
an alternate or supplemental requirement for
a particular style and placement of protection.
An example would be the use of a circuit breaker upstream
of a crowbar ov module where the breaker not only
protects wires, it's a component of a rapid response
disconnect for alternator field power.
In light of these assertions, the need for wire
protection in the e-bus normal feed path is
predicated on lengths of wires. The legacy philosophy
for leaving protection out is predicated on a length
of the at-risk path. The rule of thumb which guided
such decisions at my places of employment was that
path length of 6" or less does not require protection.
It has always been my assumption that an e-bus and
main bus structure would be located very close to
each other and the diode wires were short.
Perhaps I should have put the "6 inches or less"
flag (*) on those wires.
Power diodes almost always fail shorted. An easy
test during pre-flight is to close the alternate
feed path switch to power up for getting your ATIS
or clearance delivery . . . or just to test the
alternate path switch. If the diode is shorted, the
whole panel will light up . . . not just e-bus
appliances.
I've seen diodes fail open, but never in the passive
sense that would tend to hide their condition from
external inspection. These diodes literally exploded
leaving two wire stubs waving in the breeze. The
fat diode used for the normal feed path isolation
is not likely to fail with such fanfare . . . which
leaves shorting as the only, easily tested risk.
The short answer to your question is "no" assuming
the wires are short.
