larkrv10(at)gmail.com Guest
Posted: Wed Nov 07, 2012 7:28 pm Post subject: roll servo stop bracket |
Hi all
I installed the roll servo today and found the 2 little 6-32 x 1/4" screws that fasten the stop bracket woefully short. I got almost 1 1/2 turns on them. Searching the archives revealed a couple of posts but no definitive conclusion. Did anyone substitute the screws for something a little bit longer? I know using a screw that's too long screw can cause interference internally. I'm tempted to remove the lock washer, use a little bit of lock tite or use both.
Anyone have a better solution?
Thx
Rick
#40956
Southampton, Ont
FWF and Finish kit arrive tomorrow
davidsoutpost(at)comcast. Guest
Posted: Wed Nov 07, 2012 8:24 pm Post subject: roll servo stop bracket |
I did just that: Removed the washer and used Loctite.
David Clifford
RV-10 Builder
Howell, MI
Sent: Wednesday, November 7, 2012 10:27:30 PM
Subject: roll servo stop bracket
Hi all
Thx
Rick
#40956
Southampton, Ont
_blank">www.aeroelectric.com
" target="_blank">www.buildersbooks.com
tp://forums.matronics.com
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Thu Nov 08, 2012 5:28 am Post subject: Re: roll servo stop bracket |
Rick,
I emailed you some photos of the mod I came up with for both the pitch and roll servo brackets.
Bill
_________________ Bill
WA0SYV
Aviation Partners, LLC |
