ssvoysky(at)gmail.com Guest
Posted: Sun Nov 11, 2012 6:00 pm Post subject: Loose exhaust pipes on YAK-52 (Serge Svoysky) |
Thanks to all for the "right on point" advises provided- was able to remove the exhaust after spraying, then heating the collar with a propane torch. Now- I can't tighten it up because the insert is rotating - the little pins that were holding it seem to be missing. Looking for options. Thanks again!
On Fri, Nov 9, 2012 at 3:01 AM, Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)> wrote:
[quote]*
Today's complete Yak-List Digest can also be found in either of the
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2012-11-08&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2012-11-08&Archive=Yak
Yak-List Digest Archive
Total Messages Posted Thu 11/08/12: 4
Today's Message Index:
0. 12:15 AM - Make A List Contribution - It's Your Personal Squelch Button... (Matt Dralle)
1. 05:51 PM - Loose exhaust pipes on YAK-52 (Serge Svoysky)
2. 06:07 PM - Re: Loose exhaust pipes on YAK-52 (A. Dennis Savarese)
3. 08:25 PM - Re: Loose exhaust pipes on YAK-52 (Roger Kemp M.D.)
________________________________ Message 0 _____________________________________
Time: 12:15:46 AM PST US
From: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Subject: Make A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages.
Here's how it works... As soon as a List member makes a Contribution through
the Matronics Fund Raiser web site, their email address is automatically added
to this year's Contributor List and they instantly cease to receive further Fund
Raiser messages for the rest of the month! Its just that simple!
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site such as this one. It also goes
to pay for the commercial-grade Internet connection and to pay the huge electric
bill to keep the computer gear running and the air conditioner powered
on. I run all of the Matronics Email List and Forums sites here locally which
allows me to control and monitor every aspect of the system for the utmost in
reliably and performance. Your personal Contribution matters because, when combined
with other Listers such as yourself, it pays the bills to keep this site
up and running. I accept exactly ZERO advertising dollars for the Matronics
Lists sites. I can't stand the pop-up ads and all other commercials that are
so prevalent on the Internet these days and I particularly don't want to have
it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution to keep it that way!!
or, you can send a personal check to the following address:
Matronics / Matt Dralle
581 Jeannie Way
Livermore, CA 94550
Thank you!
[Note that there are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the given email address and since most of these are anonymous
public access methods, there is no simple way to filter them.]
Time: 05:51:49 PM PST US
Subject: Loose exhaust pipes on YAK-52
From: Serge Svoysky <ssvoysky(at)gmail.com (ssvoysky(at)gmail.com)>
Hello:
About a half-inch play was discovered after the post-flight inspection,
the exhaust pipe is loose at the point where it goes to the cylinder. Tried
to tight it with zero success. I would appreciate for the advice.
Thanks!
Serge
Time: 06:07:54 PM PST US
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Subject: Re: Loose exhaust pipes on YAK-52
It sounds like the exhaust section collar is "frozen" to the exhaust
port insert. Caused by rust on the threads of the exhaust collar.
You can try spraying such things as P B Blaster or Mouse Milk around the
threads and let it soak in for a few hours. It might loosen the rust
around the threads of the collar enough where you can rotate it. You
could also try heating the collar with a propane torch and then try
loosening it first, then tightening it. Don't assume just because you
can tighten it that everything is just fine. You _will_ need to remove
it anyway because there is a "donut" that fits between the flange of the
exhaust section flare and the exhaust port of the cylinder. It may be
totally missing. If it is, the exhaust section will not fit properly
against the exhaust port. You will need to purchase one from M14P
before you reinstall the exhaust section and tighten it up.
If the collar is rotating and it is seized to the threads, you really
should remove the cylinder and send it to Jill at M14P and let them do
their magic loosening the collar AND re-staking the exhaust port insert,
which is a left hand thread.
A. Dennis Savarese
[url=tel:334-285-6263]334-285-6263[/url]
[url=tel:334-546-8182]334-546-8182[/url] (mobile)
www.yak-52.com
Skype - Yakguy1
On 11/8/2012 7:49 PM, Serge Svoysky wrote:
> Hello:
> inspection, the exhaust pipe is loose at the point where it goes to
> the cylinder. Tried to tight it with zero success. I would appreciate
> for the advice.
> Thanks!
> Serge
Time: 08:25:32 PM PST US
From: "Roger Kemp M.D." <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
After soaking it with PBS Blaster shock the joint by tapping on it firmly with
a brass or sand hammer. That should help to break the seized threads loose.
Doc
Sent from my iPad
On Nov 8, 2012, at 8:05 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
wrote:
> It sounds like the exhaust section collar is "frozen" to the exhaust port insert.
> You can try spraying such things as P B Blaster or Mouse Milk around the threads
and let it soak in for a few hours. It might loosen the rust around the threads
of the collar enough where you can rotate it. You could also try heating
the collar with a propane torch and then try loosening it first, then tightening
it. Don't assume just because you can tighten it that everything is just
fine. You _will_ need to remove it anyway because there is a "donut" that fits
between the flange of the exhaust section flare and the exhaust port of the
cylinder. It may be totally missing. If it is, the exhaust section will not
fit properly against the exhaust port. You will need to purchase one from M14P
> If the collar is rotating and it is seized to the threads, you really should
remove the cylinder and send it to Jill at M14P and let them do their magic loosening
the collar AND re-staking the exhaust port insert, which is a left hand
thread.
> A. Dennis Savarese
> www.yak-52.com
> Skype - Yakguy1
>> Hello:
>> About a half-inch play was discovered after the post-flight inspection, the
exhaust pipe is loose at the point where it goes to the cylinder. Tried to tight
>> Thanks!
>> Serge
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
