Graeme Toft
Posted: Wed Jun 07, 2006 2:16 am Post subject: Throttle Body |
Hi Guys, I have just received my Ellison throttle body back from the USA after a factory overhaul. In the manual provided I note that Mogas/premium motor fuel is not recommended for use. I had run my engine on mogas until my accident and was unaware of any restriction on the use of particular fuels through these throttle bodies. Can anyone with the Ellison system comment on how critical this policy on burning only avgas is and if using mogas is a real no-no. I dont have a problem using avgas but sourcing it in our area is very difficult and I would like to avoid using 44 gallon storage drums if at all possible.
Graeme
smokey_bear_40220(at)yaho Guest
Posted: Wed Jun 07, 2006 10:30 pm Post subject: Throttle Body |
Hi Graeme,
What did the overhaul cost? I might do it too. I
used local fuel for 2 years until I found it had
unlabeled addatives.
| Quote: | From what I was told, they can see the damage from
alcohol right off. Don't know if it is the seals or
if the aluminum body corrodes from it. Maybe both? I
haven't called them yet on it.
kurt s.
--- QSS <msm(at)byterocky.net> wrote:
| Quote: | Hi Guys, I have just received my Ellison throttle
at all possible.
Graeme
Graeme Toft
Posted: Wed Jun 07, 2006 11:40 pm Post subject: Throttle Body |
Hi Kurt, I appreciate the reply. I have heard of people using mogas with the
TBI but wasn't sure about any issues with its use. I really would like to
continue using it but not at the expense of any damage it might cause. I
suspected the TBI had some water ingress and although many suggested I do
the overhaul myself I decided to bite the bullet and get it checked out by
the manufacturer. I have listed the work that was required to be undertaken
by them and the costs. It proved to be a wise move as apparently there was
some corrosion and damaged parts.
Labor - $151.20 (3.36 Hours (at) $45/Hr.)
Parts - $108.23
Shipping & Handling - $54.20
1. The unit was completely disassemble, inspected and cleaned.
2. Corrosion area by ICV ground out.
3. All aluminum parts etched and alodined.
4. Teflon Insert and Slide Seals epoxied into place.
5. Body & Regulator built up.
6. New ICV installed and leak checked.
7. Cracking Pressure checked and set.
8. Final assembly
9. Check and set Idle Leak Rate.
Graeme
Posted: Thu Jun 08, 2006 9:50 pm Post subject: Throttle Body |
Thanks Graeme,
That helps to know.
I want to continue using car (boat gas on floats) if I
can too. I wish they would bite the bullet and
convert the TBI's to handle additives without damage
for all of us.
Kurt S.
| Quote: | Hi Kurt, I appreciate the reply. I have heard of
Graeme
